94 ford ranger shuts off by it self??????
#805451
04/15/07 01:19 PM
i have a 94 ford ranger extnded cab that started acting really wierd. one morning i went out ot start it to let it warm up before i left for work it ran fine for a few minutes the stopped running. i went to start it and it wouldnt i shut the key off then tried to start it and it started again so i left for work it did the same thing 2 more times on my way to work. it has done this continusely since. i was thinking i had a dead spot in the pump motor. oh 1 more thing one of the times it did this i checked the pressure at thwe rail oon the motor and there was pressure there and i forgot i left the key on now correct me if im wrong but the minute i bleed the pressure off in the rail shouldnt the pump of come on?? i had to cycle the key to get the truck to start.
Re: 94 ford ranger shuts off by it self??????
[Re: ctkia]
#805452
04/28/07 04:33 AM
have you tried check/replacing your ignition switch. if that is not the culpret id suggest relays or solinoid.
tread light and save our right '92 Rodeo 3.1 5spd full manual 4x4 w/ Aisin hubs '87 F-250 460 4spd full manual 4x4 granny low
[Re: Jackyl]
#805453
05/07/07 05:08 AM
Is it just the click of the key or is it turning over and not starting. If its click of the key check you battery cables and silenoid.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5900 MB (Peak: 0.6432 MB) Data Comp: Off Server Time: 2026-06-13 10:45:21 UTCValid HTML 5 and Valid CSS
