Fuel Pump Problem On 87 4 Runner #805498 04/15/07 07:54 PM
myyota Offline OP
Once you start the truck it will only run for about 3 seconds and then dies, the power to the fuel pump goes dead, we have tried a different fuel pump relay,a different circuit opening relay and a different air flow meter, and the problem is still there. i know there is a main relay that supplys power to the other relays, were is it located ?, is it in the fuse box under the hood ?. any help is appreciated. <img src="/forums/images/graemlins/confused.gif" alt="" />
1986 Toyota 4Runner.
Solid Axle Swap, 5'' Lift, 37'' MTR`s, Duel Cases, Detroit Locker Rear, ARB High Pinion Front, 4.88 Gears, Cross Over Steering, Trail Gear Sliders, Addicted Off Road Front Bumper.
Re: Fuel Pump Problem On 87 4 Runner [Re: myyota] #805499 04/15/07 09:20 PM
4Crawler Offline
You'll find that information on my web page:
- http://www.4crawler.com/4x4/CheapTricks/index.shtml#FuelPump
Also check for air leaks in the tubing between the air filter/AFM and the throttle body.
Re: Fuel Pump Problem On 87 4 Runner [Re: 4Crawler] #805500 04/16/07 01:53 AM
myyota Offline OP
Thanks for the info, but like i said above, the truck will only run for about 3 seconds before it dies. it doesn`t matter if its warm or cold, it starts just fine, it just won`t keep running because the power to the fuel pump goes dead.
Re: Fuel Pump Problem On 87 4 Runner [Re: myyota] #805501 04/16/07 02:18 AM
4Crawler Offline
Well try the fuel pump test jumper. It bypasses most of the circuits and forces the fuel pump to stay running any time the ignition is on.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.010s) Memory: 0.6042 MB (Peak: 0.6604 MB) Data Comp: Off Server Time: 2026-07-17 00:49:00 UTC
