Winshield frame replacement... #805618 04/16/07 01:07 PM
9
93yj Offline OP
Well, after replacing the frame it has rained/snowed and now my floorboards are only HALF as wet, heh. What a friggen POS.
The cab is pretty dusty from when I cut out the floorpan rot (driver's side) so I am now able to see that water is coming in from SOMEWHERE, on both sides, from about the level of the antenna. On the passenger's side I THINK it's coming in from where the antenna mounts but on the driver's side there is a stream of water trickling down from the same spot.
Will it EVER end? <img src="/forums/images/graemlins/angry.gif" alt="" />
Re: Winshield frame replacement... [Re: 93yj] #805619 04/16/07 02:29 PM
playinmud Offline
mine leaks also but i beleive mine is coming from where the hard top meets the windshield frame or the gasket on that upper soft door isnt sealing good right in that spot i havnt had time to check it out but i will be doing so in the next couple weeks so i can buy carpet and not have to worry about it getting wet and smelling like a dog in there
WHEN THE ROAD ENDS, THE FUN BEGINS
97 sahara, 4in skyjacker lift, 33in tires, borla header & catback, 10in subs
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5861 MB (Peak: 0.6338 MB) Data Comp: Off Server Time: 2026-07-13 09:20:33 UTC
