Head gasket replacement #806285 04/18/07 02:57 AM
wrxnefx06 Offline OP
How much time am i looking at to replace a head gasket including all the misc things that have to or should be replaced(timing chain, etc) 88 22re.
Re: Head gasket replacement [Re: wrxnefx06] #806286 04/18/07 05:42 AM
Peli Offline
depends 8 to 24 hours if you have or can borrow a digi cam take lot of pics and large ones this will help when putting it back together
if you plan on cleaning everything up real well it will take longer
1989 toyota 4runner 5speed 4" lift
Re: Head gasket replacement [Re: Peli] #806287 04/18/07 01:46 PM
TexJeff87 Offline
Have you done something like this before? If not, give yourself at least two days.
Do you have the tools? Do you have a machine shop to clean and test and possibly mill the head? Do you have a plan for parts if the head is too far gone? Do you have an FSM, or at least a Haynes book? (don't use chilton!!)
What should be a relatively easy job, all things considered, can easily turn into a nightmare. It's all the little crap that will come up and bite you, like exhaust manifold studs stripping.
There is lots of info here. If you DO plan on tackling this, you need 1 part tools, 1 part parts, 3 parts methodical-ness, and 5 parts patience. Shortcuts are a <img src="/forums/images/graemlins/shame.gif" alt="" />
If Mad Max had a 4runner...
Re: Head gasket replacement [Re: TexJeff87] #806288 04/18/07 02:12 PM
gueroblanco Offline
that's for sure i once ended up doing a mazda h/g 2x because the head was warped and i didn't take the time 2 get it checked. <img src="/forums/images/graemlins/sleeping.gif" alt="" />
'95 runner 3vze/r150f
Re: Head gasket replacement [Re: gueroblanco] #806289 04/18/07 09:48 PM
I have helped rebuild a nissan altima motor with a friend, who is probably going to help with this project if it turns out the head gasket is bad. I
Re: Head gasket replacement [Re: wrxnefx06] #806290 04/19/07 01:36 AM
1
1986xtracab Offline
flat rate time is 13 hours.
1986 xtra-cab 22re
stock everything
1991 bed
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6074 MB (Peak: 0.6774 MB) Data Comp: Off Server Time: 2026-06-10 01:37:10 UTC
