What is wrong with it? *DELETED*
#806503
04/18/07 07:52 PM
Post deleted by JBSpringer
Re: What is wrong with it?
[Re: JBSpringer]
#806504
04/18/07 08:19 PM
UPDATE: I took off the outter hub on the passenger side and turned the 12mm bolt that holds the washers to the axle and the axle & drive shaft turned as well as if it was locked. Yes I did turn the hub to free before removing it.
On the other hub (driver side) when turning the same bolt the cv/axle turns but the drive shaft doesn't.
Any thoughts?
[Re: JBSpringer]
#806505
04/18/07 09:09 PM
That bolt screws into the end of the CV stub axle, so turning it will turn the axle, regardless of the hub being locked or unlocked. If the other side half axle doesn't turn, then it sounds like the CV joint on that side is broken. Grab the axle shaft and see if it moves around.
[Re: 4Crawler]
#806506
04/18/07 09:16 PM
4Crawler you are absolutely right it is the inner cv joint. I didn't think it was because the boot did not tear instead the metal shaft was spinning inside the boot.
I already looked up on how to replace it.
Thanks for your help.
[Re: JBSpringer]
#806507
04/19/07 01:50 AM
JB, if possible, remove the CV axle and take it to the parts store with you to save on the core charge; around $90 or so. <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6069 MB (Peak: 0.6714 MB) Data Comp: Off Server Time: 2026-06-20 22:18:55 UTCValid HTML 5 and Valid CSS
