Front end squeek #806521 04/18/07 09:15 PM
toy94x4 Offline OP
I'm getting a high pitched squeek from the front of my truck. It gets progressively faster with speed. I only had a quick minute earlier to jack up the front end and the drivers side tire is noticeably harder to turn and does not free spin for nearly as long as the passenger side does. My real question here is... could it be the brakes grabbing the rotor (maybe need bled, adjusted, or replaced) or is it most likely the wheel bearings (which by the way I have replaced within the last year and have not had them submerged in any water since the r2). I know that front pads have the indicators but I can't remember if they always drag when the pads are getting low or only when the brakes are applied. The squeek is not affected by the application of the brakes either. Thanks.
1994 P'up, 22RE, K&N, LCE exhaust sys (header, cat, muffler, 2.25" pipe), 1" RB seat lift, 1" RB body lift, 1.5" rear lift via shackles, Rancho 5000's, 33" Pro Comp M/T's, 4.88's w/ Aussie lockers front & back
Re: Front end squeek [Re: toy94x4] #806522 04/19/07 02:29 AM
canuck Offline
My first impression is wheel bearing(s). Pry your calipers open and then spin the wheel. If still tight then its the bearings. If wheel spins freely then its brakes. Seized caliper. Another indicator of a brake problem is after driving without using brakes are the brakes excessively hot, if so there is problem -stuck caliper.
Keep the Shiney Side up. Support our troops.
Re: Front end squeek [Re: canuck] #806523 04/21/07 11:57 PM
toy94x4 Offline OP
Well, lucky me. It turned out it was a stuck caliper. As soon as I took the caliper off, the rotor spun just fine. I went ahead and replaced both left and right. Although I did not get a chance to take the rotor's off and have them turned. I will try and get that done soon. Does anyone know somewhere cheap I can pickup that 54mm socket? I had a hard time trying to find one yesterday?
Re: Front end squeek [Re: toy94x4] #806524 04/22/07 12:02 AM
OOP'S Offline
Marlin has them or go to Sears and get a 2 1/8 socket, you will also need a 3/4 to 1/2 adapter.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6049 MB (Peak: 0.6612 MB) Data Comp: Off Server Time: 2026-05-26 04:57:29 UTC
