Tire Size help #806665 04/19/07 05:14 PM
9
99Taco Offline OP
Can I fit 33in BF Mud with a 2 1/2" lift??? Or should I go with a 3" lift. Also what size spacers should I run???
Re: Tire Size help [Re: 99Taco] #806666 04/19/07 05:26 PM
9
99Taco Offline OP
Need help ASAP going to buy lift in the next few days and need to know the Specs thanks
Re: Tire Size help [Re: 99Taco] #806667 04/19/07 05:39 PM
DentedTacoma Offline
There are some other factors to think about. I plan on putting 33x10.5 BFG MTs on my truck and know they will fit and I just have a 2" bodylift and front leveling spacers. I know that they will fit with 15x7 3.5 backspace so i will likely get 15x8 with 4.5 backspacing when all is said and done. What width were you looking at? 10.5s maybe but 12.5s are a little doubtful without trimming or doing some more thinking about wheels and backspacing. Your best bet is to try some on if you get the chance, everyones truck is a little different.
98' Toyota Tacoma SR5
Manual Xtra Cab, Slight Lift
Maine Rules!
Re: Tire Size help [Re: DentedTacoma] #806668 04/19/07 06:57 PM
9
99Taco Offline OP
ya they are going to be 33x10.5x15 so what all do I need to take into consider besides the spacer I dont want then to stick out to far but not stock width???
Re: Tire Size help [Re: 99Taco] #806669 04/19/07 07:14 PM
The more you stick the tire out the more trouble you will have in clearing them, although you dont want them to rub the frame while turning either so you might need them out a bit more. It is hard to say, I dont have mine on yet so I cant offer too much in depth advice. What I do know is that I was able to stuff 33x10.5 TSL Thornbirds on 15x7 wheels with 3.5 BS with a 2" body lift and 2" leveling spacers in the front. I cant say that all this totally applies to you though. Hopefully some others can offer some advice as well. What kind of lifts were you looking into? Why is it so time sensitive? It is important to do it right the first time to avoid burned money down the road or issues with your truck.
Maine Rules!
Re: Tire Size help [Re: DentedTacoma] #806670 04/20/07 05:30 AM
9
99Taco Offline OP
time isnt much of the problem any more Im not getting paid soon enough so I will look into more info now. But thank you for your help and how you can help me out later on down the road.
Re: Tire Size help [Re: 99Taco] #806671 04/20/07 06:34 AM
Stock02 Offline
Just stick with a 32" x 10.5" tire.
02 Tacoma Xcb 4x4, runnin 32"s, 2.5" Daystar spacers, 1.5" Downey HD shackles, AOR sliders, SkidRow Tcase skid, 20# CO2 setup
Re: Tire Size help [Re: Stock02] #806672 04/20/07 05:00 PM
9
99Taco Offline OP
The problem is that Im having the 33s given to me. But if I can fit 32s BF M/T with a 2 1/2in body lift then I will do it. But other than that I need different options that I can work with. Like a 2 1/2in body lift with 3in suspension lift. Or just a 2 1/2in body lift and fit 32s Bf M/T
Re: Tire Size help [Re: 99Taco] #806673 04/20/07 07:13 PM
You could always give the 33s to me if it makes it easier on you. Always trying to help out in any way I can.
Maine Rules!
Re: Tire Size help [Re: DentedTacoma] #806674 04/23/07 04:41 PM
9
99Taco Offline OP
Now honestly why would I want to just give away my FREE 33in Mud Terrians ???? and I think im going to go with a 3in suspension lift in the front and a 3in leaf spring lift in the rear any comments on that and will clearing be a problem?
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6350 MB (Peak: 0.7416 MB) Data Comp: Off Server Time: 2026-06-21 00:07:50 UTC
