Page 3 of 3 1 2 3
Re: ZUKlocks HOWTO: [Re: ZUK] #806850 07/10/07 10:06 AM
rednekbean Offline
Yeah that is the method we used to do in the dirt car.
I found another little trick is to seat the bead with starter fluid first than immediatly hit it with the air. When you air the tire up put it at around 30 PSI. The started fluid really gets the sealent to bond when it heats up and than at 30 PSI the bead has alot of pressure against it and really gets a good strong seal. i usually leave the tire at that pressure for atleast 24hours just to be sure.
If you dont know how to seat the bead with starter fluid either dont do it or be VERY VERY careful.
At schwabs we either use the truck press or dont touch them. At home i have always double hooped, two seperate hoops, a tow strap and than chained the wheel to the bottom of the corner fence post, 2'x2.5' block of concrete, and tied the strap to the chevy and start pulling. I had to put the chevy in 4wd to keep traction on dry asphalt...
92' Pick-up, SAS, gears to make her crawl, 37's , bullet proof motor, and alot of time invested.
06 CRF450R one mean roost flinging machine
Re: ZUKlocks HOWTO: [Re: rednekbean] #806851 07/17/07 09:07 PM
mrstang01 Offline
<img src="/forums/images/graemlins/confused.gif" alt="" />
I don't get it, what does pulling on it in 4wd have to do with seating a bead?
85 4Runner on 36's, Almost there!!!
85 4Runner on 35's, Build also in progress
89 4Runner on 31's, IFS still intact
Re: ZUKlocks HOWTO: [Re: cktoy] #806852 07/18/07 08:26 AM
dreamlineaudio Offline
Also if you do nto want to use bb's tire shops sale equal to put in your tires. This is how Les Schwab balances semi-tires and sometimes 4x4 rigs if requested by owner. It should work the best from what I understand.
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.010s) Memory: 0.6012 MB (Peak: 0.6707 MB) Data Comp: Off Server Time: 2026-07-17 01:12:55 UTC
