Re: Ack....HG going out again. [Re: fire4effect] #806889 04/23/07 11:24 PM
eightyeight Offline
torque to yeild bolts usually have about 2-3 torqing sequences in them before they are stretched enough to be junk. Usually, if its the first time the head gaskets are done re-using the bolts is OK. There are a LOT of torque to yeild bolts in a modern engine. few are ever replaced.
for the record, any automaker i know of recommends replacing torque to yeild bolts when re-assebmled.
-matt
-'88 toy x-cab, SAS, chevys, gears, lockers, free tires, dented body mod.
-'87 4runner, bone stock DD
"It's OK to do stupid things, as long as you are not stupid about it."
Re: Ack....HG going out again. [Re: fire4effect] #806890 04/24/07 03:51 AM
mxben Offline
Torque to yield bolts are called that way for the yield point in the tensile strenght of steel. The yield point is the level of strenght a material can take before getting permanent deformation. Below that point, the piece will get back to is original shape when you unload it. For example, a spring should always be used below is yield strength otherwise it wont get back to is shape. A torque to yield bolt means that you should torque it just at the point that the bolt will extend slightly and will never get back to it's original lenght. I get this from my studies in mechanical engineering. While this doesn't mean that they WILL cause a gasket leak, I think that's enough to put them in the garbage and buy new ones. I wouldn't take take risk. It's clear that no manufacturer would recommend using them twice and a quality workshop shouln't either. Good luck dealing with these poor mechanic's !
(I'm sorry for my english mistakes, I usually speak french)
Re: Ack....HG going out again. [Re: mxben] #806891 04/24/07 05:49 AM
O
OutlawMike Offline
I just typed this in and re-read it. I'm hoping it is not too preachy, high minded, etc. I think it has value to put out there in front of everyone, but I apologize if anyone falls asleep or strains their eyes from rolling them too much:
Might as well chime in on this subject, put my BSME on the table.
Torque to yield bolts were developed in response to the changing materials used in engine design. When OEM's started putting aluminum cylinder heads on cast iron blocks they found out (the hard way sometimes) that the varying rates of thermal expansion between the cast iron block and the aluminum head could not tolerate the low accuracy of the normal "torque to torque spec" bolts. They needed a better way of ensuring that all of the bolts in the assembly were applying the correct, even preload to the assembly.
When you start working on these type of engines you see this crazy order of operations. Torque to some low torque spec in a particular pattern, then (in the same pattern) an additional 90 degrees, then another 90 degrees in the same pattern. Why is this?
In general, for iron based alloy bolts, during tightening to failure (we have all experienced this at some point) the bolt goes through 4 phases: Elastic region, Yield Point, Plastic Region, and Ultimate Failure Point.
In the Elastic region, as all of our old torque to torque spec bolts were designed for, the bolt is a spring. We tighten it, it stores energy by stretching, but, when we loosen it, it will return to it's original length. Kind of like a torsion spring on the early IFS, it elastically deforms all the time as you drive down the road, but returns to its original position when you take the preload off of it.
The Yield Point is the stress point in the material that results in permanent deformation of the bolt. It is the transition point between Elastic and Plastic.
Once in the Plastic region of the stress/strain curve the bolt will take a permanent deformation to it's length. When you take the load off of a bolt that has been plasticly deformed it will be longer by some amount, depending on how far past the yield point it has been "turned".
The Ultimate Failure Point, is a point that we all know and love. It is that point where the bolt rapidly fails and the applied torque falls off rapidly for any given increase in length/rotation. You know the feeling, oh crap, the wrench is moving easier, now, damn, even easier, like stepping on a rotten plum. Damn, I snapped the bolt.
So, now that I bored everyone to death with the above explanation of Elastic, Yield, Plastic, and Ultimate Failure, why do we use torque to yield bolts?
The tightening of bolts is an in-exact science. The "recorded" torque on a torque wrench is dependant on a litany of factors, including the clearance between the tapped hole and the bolt, the surface finish of the threads, the presence (or not) of lubricant, etc, etc.
To eliminate a significant number of these factors, torque to yield bolts are used.
The initial "snug torque" is used to ensure, as best as possible, that all of the bolts start out at the same frame of reference. All of the bolts and washers should be oiled. The low torque that is specified does not kick in a number of the "uncertainty factors" associated with the thread geometry. So, now you have all the bolts at common reference point.
The next step is to ensure that they are all torqued PAST YIELD POINT, not too yield, not before yield, but past. A stress-strain curve has a flat point in it after yield (iron based bolts). If all of the bolts are torqued past yield into the flat spot in the curve they have (about) the same preload, if you tighten it any more it just permanently stretches, will not store any more energy.
This is where the angle of turn spec comes from. You know the bolts are at a common reference point, so, now you turn them a certain angle, which you know will create a given increase in length of the bolt (thread geometry). If the engineer has done his homework, he knows that if he starts at the common reference point (low torque, oiled bolts) and then turns the bolt a certain number of degrees, all of the bolts will be in the flat portion of the Plastic Region.
If you have done heads with torque to yield bolts you know the feeling when they yield. The force applied to make the bolt turn keeps getting harder, but then, it breaks over and stays the same. Some break over on the first 90 degrees, some on the second, but they all go into the flat region of the stress strain curve.
Now, if you re-use a bolt that has gone through this operation, you are using a bolt that has stretched how far? No way to know, for sure. You can't know, it might have yielded early or late in the sequence.
If it yielded early, and you re-use it, you will push the bolt to far towards the Ultimate Failure Point. It sees a few thermal cylces on the engine, and bam, blown head gasket.
My advice, do not reuse torque to yield bolts. They might work, they might not.
I wonder if this is why everyone sees so many second and third blown head gaskets? Same damn bolts used again, and again, and again.
RockAuto.com, $24 per 8 (3VZE), $50 bones for a full set.
Sorry for the long post, had to do it justice.
Mike
Re: Ack....HG going out again. [Re: OutlawMike] #806892 04/24/07 05:38 PM
Bustedback Offline
Thank you for a very informative and well said post. I think a few of us may have learned something by reading it.
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Ack....HG going out again. [Re: fire4effect] #806893 04/24/07 10:00 PM
U
uglytruck Offline
TTY bolts can't be a secret, so why the resistance?
because the mechanics realized they screwed up and dont want to have to do the job over again for no money!
it's sad but unfourtunatly it's true
which is why i try to as much as possible do jobs myself anymore because you just dont know if you can trust them...
that and if i screw up i cant blame anyone but myself
88 4runner sr5 v6
needs a lift!
-formerly 86yodaputruck
Re: Ack....HG going out again. [Re: Bustedback] #806894 04/24/07 11:14 PM
fire4effect Offline OP
Ok...3rd time is a charm...my posts aren't getting posted <img src="/forums/images/graemlins/zombie.gif" alt="" />
Here is the reply form my old mech. Basically, they just followed what the dealers did, not what the FSM recommends. I don't think this is unique to this shop, because I've asked several as an informal survey and haven't found 1 that said they outright replace the head bolts....most say "depends".
I'm going to post Mike's response and see what he says.
Alfred, Most of my tech's worked for the local Toyota dealers & along with myself did plenty of head gaskets on 3.0L's. All of the warr.3.0L gasket jobs never got new head bolts. This "Dealer" trend has carried over to the independent shops. But it's true Toyota's factory repair manual recommends charging customers for all new head bolts.This add's over $100.00 to the bill & we can't tell the customer it will make a diff.or not. Just to show you how grey this all is, check out the "knock sensor & wire". They (Toyota) don't say anything about these two items (that add $180.00) to the bill yet after performing the head gasket work guess what?Now you have a check engine lamp on that was never there before & when the system is tested........."knock sensor" Yup! & now it will cost $625.00 to go back in and replace the sensor & wire. What I'm saying is much of this is a "judgement call" & knowing the beast your working on helps. In your case pulling the head & replacing gaskets & head bolts will be the cure most likely.
Semper Fi,
Alfred
'91 4Runner V6 4WD 400+K
'10 Scion Xb
Re: Ack....HG going out again. [Re: OutlawMike] #806895 04/25/07 01:56 AM
E
EtienneNavaar Offline
An easy way to get the correct torque on any bolt is to follow this simple plan. Tighten the bolt until it turns easy, then back it up half a turn. Done.
Of course I'm kidding, I just wanted to say thanks to OutlawMike for taking the time to explain to us about torque and bolts. So thanks Mike.
Re: Ack....HG going out again. [Re: OutlawMike] #806896 04/25/07 02:07 AM
Snowtoy Offline
II wonder if this is why everyone sees so many second and third blown head gaskets? Same damn bolts used again, and again, and again.
This is exactly what my local Toyota Service manager said as to why HG jobs tend to fail the second timne around, that and warped heads, when I asked. A friend of mine owns his own shop and he told me the same thing. Before he had two V6's come back with bad HG w/in a year he started using new headbolts, and eating the labor/parts to do a job again. He also started replacing the knock sensor and wire, because he had rigs come back after he fixed HG with engine light on. He now turns away any customer who will not authorize new headbolts and knock senor/wire.
Thanks for the informative post.
Re: Ack....HG going out again. [Re: uglytruck] #806897 04/25/07 02:16 AM
Snowtoy Offline
Exactly, that and if their quote is a few hunderd cheaper than the next guys they will likely get the job.
It isn't that much of a secret anymore, and should have only been back in the mid to late '90's when the HG problem began.
Re: Ack....HG going out again. [Re: fire4effect] #806898 04/25/07 02:24 AM
Snowtoy Offline
Most of my tech's worked for the local Toyota dealers & along with myself did plenty of head gaskets on 3.0L's. All of the warr.3.0L gasket jobs never got new head bolts. This "Dealer" trend has carried over to the independent shops. But it's true Toyota's factory repair manual recommends charging customers for all new head bolts.This add's over $100.00 to the bill & we can't tell the customer it will make a diff.or not. What I'm saying is much of this is a "judgement call" & knowing the beast your working on helps. In your case pulling the head & replacing gaskets & head bolts will be the cure most likely.
This isn't a valid reason here for not replacing them, and wont keep a shop rom having to redo the job at their cost, if you were to file a claim against them in court. The FSM recommends it therefore they should replace them, not leave it up to a judgement call, it has nothing to do with knowing the individual beast you are working on. Also the tech posting above will show exactly why a shop should replace the headbolts and not leave it up to chance. They are betting/hoping the old headbolts will work, and if they don't work you will just blame the engine and sell the truck.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6474 MB (Peak: 0.7819 MB) Data Comp: Off Server Time: 2026-05-29 17:24:57 UTC
