?????Oil Pressure????? #807006 04/21/07 03:11 AM
Texrok Offline OP
OK I have a 1994 Yota 4x4 with a 3.0L with about 140K miles on it. I have only had the truck less than a year. I noticed the other day on a trip that the oil pressure guage at an idle is on the the first left hand mark and as I accererate and maintain a highway speed it increases and settles out in what I would call a normal possition "next mark on the right hand side. Does this sound normal for the pressure to very that much? Any feedback would be great.
Re: ?????Oil Pressure????? [Re: Texrok] #807007 04/21/07 03:30 AM
DRTDEVL Offline
Normal.
The pump is spinning slowly at idle, thus lower pressure. When you increase engine RPM, the pump speed increases accordingly, and the pressure rises.
Re: ?????Oil Pressure????? [Re: Texrok] #807008 04/21/07 04:10 AM
canuck Offline
Not sure where you live but presume DFW is Dallas Fort Worth( I'm from Canada and only speculating). You may want to consider using a thicker oil in the warm/hot weather. I'm changing my oil this weekend and putting in a thicker oil as opposed to a thin winter oil. We are in the low 70's and I noticed my pressure drop a little.
Keep the Shiney Side up. Support our troops.
Re: ?????Oil Pressure????? [Re: canuck] #807009 04/21/07 04:42 AM
Texrok Offline OP
Good point, I just changed the oil not to long ago. I put in a 10w30. I may try a 10w-40 next time. I don't mean to sound like a dumbass in this question, but I bought the truck from my dad and I don't drive it everyday because I have a work truck. Which really sucks because I really like to drive the truck. The sticker in the window from when my dad owned said 10w-30 so that is what I got.
I just wanted to make sure I wasn't developing a possible problem. The truck runs great, has no leaks, and the oil level on the dipstick is right on. Thanks for the input guys.
Re: ?????Oil Pressure????? [Re: Texrok] #807010 04/21/07 06:03 AM
Snowtoy Offline
My 3.0 does/did(stock gauge is now unplugged) the same thing. Originally it only dropped that low when at idle, then started doing it on the highway when holding at a constant speed. I installed an aftermarket guage to get a better reading, the pressure is at the high end of specs when warming up, and is above 55psi when cruising down the highway.
10/30 weight should be fine for you year round, that is all I have ever used, and the weather temps the truck runs in range from 115 in the summer to teens in the winter.
Re: ?????Oil Pressure????? [Re: Snowtoy] #807011 04/21/07 02:43 PM
OOP'S Offline
Mine is the same and I to run 10/30 year round.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: ?????Oil Pressure????? [Re: OOP'S] #807012 04/21/07 03:21 PM
Texrok Offline OP
Ok this is good news. Like I said I don't drive the truck but on the weekends so event though I have had it about a year I am really not familiar with all it's little quirks. Thanks for the input guys. I just wanted to make sure all is well.
Tex
Re: ?????Oil Pressure????? [Re: Texrok] #807013 04/21/07 04:20 PM
4Crawler Offline
I find the same thing on my 22RE. If I run at least a xxW40 weight oil, the idle pressure stays up in the normal range. If I run xxW30 it'll drop below the marked range on the gauge when the engine is hot. So I usually run a 15W40 or 20W50 oil year round.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6260 MB (Peak: 0.7218 MB) Data Comp: Off Server Time: 2026-06-20 22:18:17 UTC
