V-6 Swap #807022 04/21/07 04:04 AM
F
Forunner Offline OP
Does anyone know what it's gonna take to swap in a fuel injected Toyota V-6 in place of my fuel injected 22R-E four banger? Will the stock tranny work with it? What about the computer and all the wiring? I have 1990 Toyota 4Runner 4X4 with the 22RE four cylinder with a 5-speed manual tranny. It just doesn't have the pulling power that I need. Is there any other options? I can't pull my atv over a steep bridge any faster than 40mph. On level ground it pulls just fine but I'm scared that I'm going to get run over on the bridge. Other than the pulling power, I love the truck.
1990 Toyota 4-Runner 4x4
22RE fuel injected 4 cyl
5-speed manual
31x10.50 Dunlop Mud Rovers
all stock
Re: V-6 Swap [Re: Forunner] #807023 04/21/07 11:28 AM
Kutter Offline
http://www.offroadsolutions.com/technicalarticles/34l_conversion_kit.htm#Intro
This link above is mainly for the 3.0 to 3.4 swap. Just to get an idea. Call them they may be able to guide you. If you are going to swap I would go straight to 3.4 don't waste time and money with 3.0.
1995 4Runner Limited V6 3.4 Liter 5 Speed 4x4
1995 4Runner V6 Auto 2WD
Re: V-6 Swap [Re: Forunner] #807024 04/21/07 03:14 PM
Adam F Offline
To answer your question specifically, NO, a V6 will not bolt up to your truck, transmission, or your wiring harness.
97 4R, stock, daily driver
Re: V-6 Swap [Re: Adam F] #807025 04/21/07 10:59 PM
rollin Offline
You might look at Downey Offroad because the offer adapter kits to mount other engines in to 4Runners.
Re: V-6 Swap [Re: rollin] #807026 04/23/07 12:02 AM
F
Forunner Offline OP
Thanks for all the replys. Is there anything else that I can do to bump up towing power and grunt that this truck has with the existing motor?
5-speed manual
all stock
Re: V-6 Swap [Re: Forunner] #807027 04/23/07 04:26 AM
DRTDEVL Offline
Take a gander at http://www.engnbldr.com/ ... He has everything you need to make your 105 hp 22RE into a 140 hp 22RE. Get the 261*c cam for a lot more bottom-end grunt, the 268* for mid-range power, and the 270* for the high speed Runner!
Re: V-6 Swap [Re: Forunner] #807028 04/23/07 05:13 AM
kewlynx Offline
You've got oversized tires on that truck. REGEAR. Your cheapest avenue.
x 2 on what Adam said.
Zuk's page www.gearinstalls.com <img src="/forums/images/graemlins/kewl.gif" alt="" />
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6175 MB (Peak: 0.6917 MB) Data Comp: Off Server Time: 2026-06-22 06:05:09 UTC
