99 montero A/C question #807273 04/22/07 04:07 PM
dick0309 Offline OP
hi folks,
it is hot yesterday in New York. I feel my A/C is not really cold. I think the freon probably is low. So I am trying to check it out and charge it. But the problem is I can not locate the freon check window. I found the black bottle with a cap mark "H" just behind the driver side grille. I check the service manual it shoe the same location. But I still can not find it. Stupid me <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" />
I can not find the low service port either. can somebody tell me where it is. really apprecaited.
Dick <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: 99 montero A/C question [Re: dick0309] #807274 04/22/07 05:31 PM
Scottie2113 Offline
the low service port is on the a/c pump
the window is on the top of that black bottle you found with the high service port. it should be a little sight glass a little smaller in size than a dime. if you have truck running with a/c on, you should see stuff moving through the glass as the system cycles.
97 Montero SR w/Mitsu Adj Shocks & Rear Diff Lock ARB Front Diff Lock 4.9 Ring/Pinion 3.15 transfer box 43:1 crawl ratio 2" suspen lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs 15x10 Wheels Rock Sliderz ARB front bumper w/12k winch Custom rear bumper
Re: 99 montero A/C question [Re: dick0309] #807275 04/22/07 06:32 PM
DirtyOldTown Offline
If you get a small container of R-134a and the hose to hook it up to the car, you should be able to recharge the system pretty easily, but you need to be careful. Because your low-side fitting is on the compressor, the chances are greater that you can damage/ruin the compressor by allowing liquid to enter. When you charge your A/C system, don't turn the can upside down - leave it right side up. It will take longer, but you won't hurt the compressor. If you want to make it charge a bit faster you can place the R-134a can into some warm water to increase its pressure.
'91 LWB, 31x10.5s, KYBs, A/T "I look like Robert De Niro, I drive a Mitsubishi Pajero" - Billy Bragg (not the original lyrics, but that's how he sang it when I saw him in Dublin in '04)
Re: 99 montero A/C question [Re: Scottie2113] #807276 04/23/07 07:27 PM
dick0309 Offline OP
thanks for your help. however it is not there. <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" />
i have attached picture here
[img]http://tw.pg.photos.yahoo.com/ph/dick0309/detail?.dir=/e6care2&.dnm=4fdbre2.jpg&.src=ph[/img]
Mine is 99 Montero (not support), is it different than yours ?
Re: 99 montero A/C question [Re: dick0309] #807277 04/24/07 03:55 AM
If you are looking for the sight glass (the window you mentioned), there may not be one. Not all A/C systems have them. If there were one it would likely be on top of your receiver-drier, but looking at your picture there isn't one there - only the high-side service port. Your low-side lines will be larger in diameter than your high-side lines. What you need to do to find the low-side service port is follow the larger line coming off the compressor. If you follow it all the way back to the firewall, you're bound to find the low-side fitting. Though the low-side line is larger than the high-side line, the low-side fitting will be smaller, and it may have a platic cap with an "L" on it. Like Scottie said, the fitting may be on the compressor itsself. It could be anywhere between the compressor and the firewall.
Re: 99 montero A/C question [Re: DirtyOldTown] #807278 04/24/07 05:01 PM
dick0309 Offline OP
thank you for your detail explanation. I will try to figure it out what tis the problem of my A/C systems.
Dick <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6133 MB (Peak: 0.6845 MB) Data Comp: Off Server Time: 2026-06-07 07:01:22 UTC
