Fan clutch pully siezed 3.0L? #807805 04/24/07 08:10 PM
1
1994Runner4X4 Offline OP
Hey guys, I just had a bad start to the day. I was on my way to a job interview and notice a clicking/rubbing sound coming from the engine. I didn't think anything of it and continued with my day. On my way home I noticed it again. I got about a block away from my house and the squealing began. It died. I started it, it died. So I started and gassed it home. I pooped the hood and smoke bellowed out from the engine, and notice the belt for Alt/Fan/Crank was twisted and tangled around the fan clutch. The PS/Fan/Crank belt was half melted and I pulled it off. AC belt has been off for some time. The Alt and PS Pulleys seem fine but the pulley that the fan clutch is connected to does not move by hand. Any suggestions? What is the specific name for the pulley? Thanks for the help fellas.
1994 Toyota 4Runner SR5 3.0L M/T 4X4 w/ Full OME Sus & 1-1/2"BJS
1993 Toyota Pickup 2.4L M/T
1999 Jeep XJ "Classic" 4.0L A/T 4X4
Re: Fan clutch pully siezed 3.0L? [Re: 1994Runner4X4] #807806 04/24/07 10:02 PM
1
Well I found out it is the "Fan Bracket Assembly" and the deal sells them for a little over $500. I found another place that sells a new after market one for $250. Anyone found one cheaper? and is this hard to replace? it doesn't look that hard of a job.
Re: Fan clutch pully siezed 3.0L? [Re: 1994Runner4X4] #807807 04/25/07 01:33 AM
8
854x4 Offline
This is a fairly common problem with the toyota V6 along with the headgasket.I got one for 175 new at a wrecking yard. You could try ebay I've seen some on there for less then 100 shipped but I dont know about the quality. As for replacing it the job is easy as long as you have basic mechanic skills it should be no problem.Here is a link to a factory service manual if you need help http://personal.utulsa.edu/~nathan-buchanan/93fsm/
Re: Fan clutch pully siezed 3.0L? [Re: 854x4] #807808 04/25/07 04:04 AM
1
do I have to remove the timing belt to do this?
Re: Fan clutch pully siezed 3.0L? [Re: 1994Runner4X4] #807809 04/25/07 05:09 AM
kewlynx Offline
Check the link he gave you.
x2 on fleabay for the fan brackets. Parts Dinosaur is in PHX. Sells a lot of Yota stuff. Don't ask me how he is; won't ship to Alaska. <img src="/forums/images/graemlins/angry.gif" alt="" />
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6068 MB (Peak: 0.6716 MB) Data Comp: Off Server Time: 2026-11-02 12:30:05 UTC
