Page 3 of 3 1 2 3
Re: Is there a good idler arm yet? [Re: fasteddy] #807927 05/01/07 04:42 AM
fleetbob1 Offline
Try Moog -----They seem to last longer
1990 Montero LWB V6 5-SP Locked Rear/33/12.50 Kumho KL-71 Mud Terrains/3" body lift,bars/springs/poly/shocks/custom skids/lots of lights/snorkle/etc......
Re: Is there a good idler arm yet? [Re: fasteddy] #807928 05/01/07 08:07 AM
F.E., Lloyd Swartz used to run one, but with generally negative reports...could maybe have been from hard use/lack of maintenance, though. He was/is running 35's, also.
Re: Is there a good idler arm yet? [Re: off-roader] #807929 05/04/07 01:24 AM
KrzyDav Offline OP
What is the part # for Mitsu brand bushings?
There isn't a dealer in these parts so I have to order from rockville.
I run 31s and use the Raider daily use ,,,very little off road.
As for using a steering box , don't you have to use an English right hand side box??
dave h.
Re: Is there a good idler arm yet? [Re: KrzyDav] #807930 05/04/07 04:42 AM
CAPS shows 2 part numbers
PNC: 47105
Part No: MB243982 & MB 673524
Name: Bushing, Steering Lin <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Is there a good idler arm yet? [Re: off-roader] #807931 05/04/07 12:00 PM
Y
yankneck696 Offline
For steering box use, just mount it in the 3 holes for idler arm & swap the pitman arm 180 degrees. Might need some disassembly, too.
Ed
Yankneck = Yankee ingenuity with Redneck stupidity.
"How can I break it better?"
89 Raider 3.0 w/ 31's for now
Re: Is there a good idler arm yet? [Re: KrzyDav] #807932 05/04/07 04:21 PM
Kevin C Offline
The moog is just a re-packaged part from Japan. Mine did not last very long. I found that the factory arm and bushings held up better. From what I saw the factory bushings were a bit harder.
I dont have access to a lathe and a mill since I moved so I wont be converting any more arm for a while.
Kevin
Re: Is there a good idler arm yet? [Re: Kevin C] #807933 05/07/07 07:06 AM
MonkeyProof Offline
kinda glad i came across this thread becouse i was about to
purchase a complete idlearm asymbly from the dealership, gonna be my 2nd one in fact. i had no idea that the i can possibly replace the bushings inside. i was wondering if anyone has tried or thought of replacing the bushings with polyeurothane bushings. i always see those polyeurothane swaybar kits in different diameters at Pepboys and other parts store. maybe having that type of composition will hold up longer. does anyone know what the diameters are becouse i would like to look into it.
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6256 MB (Peak: 0.7165 MB) Data Comp: Off Server Time: 2026-06-10 01:35:36 UTC
