Problem with ARB compressor #808033 04/25/07 08:21 PM
Storm Trooper Offline OP
Hello,
Earlier in the year, i installed an ARB compressor into the trooper. Lately, I seem to be having an issue with it. I flip the switch and it kicks on to fill the little tank on it. After it reaches pressure and the pump turns off, it wont come back on. I think it tries to, but it ends up blowing the in-line fuse. Anybody have any thougts as to what is causing it?
Thanks
'91 Trooper
3.4 V6, K&N, 33x12.5 Trxus MT's, Aisin hubs, 3" body lift, Rear ARB Naches Trail
Re: Problem with ARB compressor [Re: Storm Trooper] #808034 04/26/07 03:13 AM
L
Ldub Offline
I don't have an on board compressor, so take this FWIW...
Whenever I have a compressor plugged in to run nail guns etc. & it blows the breakers when it kicks in, it's always due to being plugged in to a circut that doesn't have enough amperage.
I would assume this would work the same on a 12v dc system.
Just my FNG opinion.
Larry W - 99 VX s/c
3" lift w/trimming & BFH mods, rollin' on 33/12.50x20" Nitto Mud Graps. Indy 4x h-d tie rods, lower links & a bunch of other stuff that put the hurt on the wallet.
Re: Problem with ARB compressor [Re: Ldub] #808035 04/26/07 04:27 PM
Hmm. I'll check that out.
The weird thing is that it worked fine for a while.
I've got a question in to ARB, just waiting for a response.
'91 Trooper
Re: Problem with ARB compressor [Re: Storm Trooper] #808036 04/26/07 04:35 PM
Jim_Paget Offline
It may be that your compressor is overheating, either because of an internal problem or because of where you mounted it.
Do you have the quick disconnect for inflating tires? If so, open the hood and then turn on the compressor. Use the disconnect to drain the tank to see if it will activate then. If it does, then you likely have an overheating problem.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: Problem with ARB compressor [Re: Jim_Paget] #808037 04/26/07 06:28 PM
Thanks Jim.
I'll try that.
'91 Trooper
Re: Problem with ARB compressor [Re: Storm Trooper] #808038 04/27/07 04:21 AM
Jim_Paget Offline
You're welcome, almost neighbor <img src="/forums/images/graemlins/smile.gif" alt="" />
Jim Paget
www.rrr4x4.com
Re: Problem with ARB compressor [Re: Jim_Paget] #808039 04/27/07 10:42 PM
Yeah, no kidding huh?
Crazy thing is that I saw you more when I lived in Yakima 6 years ago.
I went to walker valley a couple of months ago. IT was tough.
Anyway, back to the subject. I get a reply from ARB. I'm sending it back to them for a replacement.
'91 Trooper
Re: Problem with ARB compressor [Re: Storm Trooper] #808040 04/28/07 01:26 AM
Jim_Paget Offline
I live about 1 mile from where you turn off Highway 9 to go to Walker Valley.
Jim Paget
www.rrr4x4.com
Re: Problem with ARB compressor [Re: Storm Trooper] #808041 05/04/07 06:26 AM
AIR AMIGO Offline
I just replaced mine. It overheated on my last run, and it melted at the first big connector leaving the ARB unit. I ended up replacing it, and redoing all the wiring while I was at it. I got 9 years out of it, so I'm not complaining.
Keith
"AIR AMIGO!" aka 1994 Isuzu Amigo SAS with Toyota axles, 5.29's, dual ARB's, IROK's, WARN HS9500 winch, and etc.
Pacific NW Isuzu Off-Roaders
Timber Tamers #172
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6264 MB (Peak: 0.7301 MB) Data Comp: Off Server Time: 2026-07-13 15:48:31 UTC
