Acceleration hiccup - trooper been sitting for a while *Fixed* #808044 04/25/07 08:54 PM
Nick Muzzio Offline OP
Hello all, been a while. I am resurrecting my trooper for a trip across the states. She's running OK after sitting for a while starts up fine, idles fine, but when I go to accelerate for the first time (like after I take my foot off the pedal, then press again) it gives me like a hiccup then goes. If I press the pedal down very slowly it seems to rev up fine.
Just curious if anyone has any quick idea I can check out before my trip.
Thanks.
1991 Trooper 3.4L engine, 4.3L throttle, Standard Tranny.
91 Trooper LS, 5 Speed Manual
3.4L Engine w/4.3L Throttle Body
Snorkel, 31" Pro Comp MT Tires, 2"lift,
ProComp ES9000 shocks and steering stabilizer
http://members.cardomain.com/sun_thief
Re: Acceleration hiccup - trooper been sitting for a while [Re: Nick Muzzio] #808045 04/25/07 09:19 PM
F
Fujisawa_Rob Offline
Does it feel like it's going to run out of gas?
Could be a sticky EGR...might not set a code. Try working the EGR valve around with your finger. Does it only do it on the first acceleration, or intermittently?
2000 Mitsubishi Montero Endeavor, "Katsumi", 138k
1993 Toyota Tercel, backup vehicle, 93k
1989 Isuzu Trooper, "Beniko", R.I.P. at 233k
My 'Genuine Isuzu Parts' decals - for sale
Re: Acceleration hiccup - trooper been sitting for a while [Re: Fujisawa_Rob] #808046 04/25/07 11:08 PM
Shovel Offline
remove, clean, lubricate, and reinstall IAC motor... go through the reset procedure (do a search on the forum)
A slow IAC will cause a stutter.
check smoothness (impedance) of TPS sweep. calibrate using the oblong mount holes for 0.5v at closed throttle.
A dead spot will cause a stutter.
inspect injector spray pattern. a dripping injector will cause a pool, which will cause a stutter smile
HTH
Re: Acceleration hiccup - trooper been sitting for a while [Re: Shovel] #808047 04/26/07 01:50 AM
Thanks for the ideas, unfortionetly It was my own fault. It looks like the Throttle Position Sensor (TPS) was unplugged. She sounds a lot better now. Thanks again for the help.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6025 MB (Peak: 0.6590 MB) Data Comp: Off Server Time: 2026-06-17 13:43:50 UTC
