2001 3.2L V6 won't start!! Help PLZ!!! #808183 04/26/07 08:36 AM
blackdemon Offline OP
I was driving my truck; after I parked it for a few minutes and tried to start it and it stared for just a second and now wonÆt start at all<img src="/forums/images/graemlins/confused.gif" alt="" />
I check the engine and everything looked ok, then I found a blown fuse in the eng. compartment, the fuse cover says is for [ACG-S] any body knows what that is?
Finally I pulled my truck down to the local Shucks and the OBD diagnostic gave me this code ôP1290ö
Any Ideas?
Thanks
Sal
~1992 Isuzu Amigo 4x4~
* 3.2L DOCH V6
* 01 Rodeo Dash-board swap
* 32's
* custom roof rack
* custom exhaust
Re: 2001 3.2L V6 won't start!! Help PLZ!!! [Re: blackdemon] #808184 04/26/07 02:53 PM
A
atfdmike Offline
I suspect that the code may have set when whatever caused the fuse to blow occured. Have you replaced the fuse yet? I think the "ags" just stands for the fuse type, and usually is followed by the amp rating. One guys opinion.
Re: 2001 3.2L V6 won't start!! Help PLZ!!! [Re: atfdmike] #808185 04/26/07 07:00 PM
Yes, I did replace the fuse, that was the first thing I fix... and every time I try to start it... nothing happened to the new fuse.
I check on line on many web-sites for OBD-II codes and none had this specific code for Isuzus...there was one site that had the mining of this code but it was for GM's...are 3.2L related to GM's?
Thanks for your reply
Sal
* 3.2L DOCH V6
* 32's
* custom roof rack
* custom exhaust
Re: 2001 3.2L V6 won't start!! Help PLZ!!! [Re: blackdemon] #808186 04/26/07 11:00 PM
spence121 Offline
Does it make any sound at all??? If not try tapping the starter. I know it's a long shot but a friend of mine just went through a similar experience with his yota. Thought it was a fuse or a battery and it turned out to be just a coincidence that the battery died and he blew the ignition fuse. After buggering around with his rig at 4 in the morning for an hour and a half, we finally figured it out.
"WE ARE ALL A PRODUCT OF OUR OWN DECISIONS"
92 Mitsubishi Pajero XR 2.5 TD (SOLD and feeling lost without it)
OME Suspension
American Racing steel Wheels with
Dick Cepek FCII Tires
Re: 2001 3.2L V6 won't start!! Help PLZ!!! [Re: spence121] #808187 04/28/07 09:23 PM
NATO308 Offline
Check here for OBD2 codes:
http://autorepair.about.com/cs/troubleshooting/l/bl_obd_main.htm
Try disconnecting the battery for a couple minutes, should clear any codes, of course you will loose your radio presets.
'94, and '00 Amigos and '00, 01 Rodeos. Rodeo springs and aftermarket 'hard top on 94. Aisin hubs OME 919's on the 2000 Amigo. 2000 and 2001 Rodeos have OME 912's and Aisin. Smoother ride with the OME 919's???
Re: 2001 3.2L V6 won't start!! Help PLZ!!! [Re: NATO308] #808188 04/28/07 11:58 PM
Jeff Mason Offline
If you have a fuel line pressure tester, you can test the pressure at the fuel rail (under the plastic plenum cover on the driver side of the engine, IIRC).
Otherwise, I would take the few $$s and few minutes of time to replace the fuel filter back by the tank. The 3.2's will NOT start if there is inadequate fuel pressure getting to the rails...
Jeff Mason
Whatever makes you upset in someone else...also exists in you
Re: 2001 3.2L V6 won't start!! Help PLZ!!! [Re: Jeff Mason] #808189 04/30/07 08:09 PM
Thanks for your repliesà.
I got a felling it has something to do with fuel. I check some codes in many sites and this is what I found.
CODE - MAKE - DESCRIPTION
P1290 - GM - Electronic Throttle Control Forced Idle Mode
P1290 - CRYSLER - CNG Fuel Pressure Too High
P1290 - FORD - CHT Sensor Low Input
Still canÆt find anything that specifies about Isuzu.
I donÆt have a fuel line pressure testerà so I will try to change the fuel filter since it has never been change as far as I know.
Thanks all you guys for your info.
* 3.2L DOCH V6
* 32's
* custom roof rack
* custom exhaust
Re: 2001 3.2L V6 won't start!! Help PLZ!!! [Re: blackdemon] #808190 05/01/07 03:27 AM
Richard Saylor Offline
Per this link over at PlanetIsuzoo, p1290 is "ETC Forced Idle Mode"
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6234 MB (Peak: 0.7225 MB) Data Comp: Off Server Time: 2026-07-13 02:39:35 UTC
