Looking for input about a body lift and tires #808218 04/26/07 05:54 PM
F
Firecrotch Offline OP
Ok im looking for a Jeep for my next car, something somewhere ind the mid '90s. Just something 4x4 so i can have some fun. I was wondering what kind of tires and how big i should go with them? and also how big of a body lift i should get. Not something to outragious but just something to get me around if i would go mudding.
Thanks, Jake
Re: Looking for input about a body lift and tires [Re: Firecrotch] #808219 04/26/07 10:05 PM
BobRowe Offline
I think that before you decide on what size tires and how big of a lift, you need to decide on what type (model) of Jeep you want.
Re: Looking for input about a body lift and tires [Re: BobRowe] #808220 04/26/07 10:37 PM
Sc0rp10n Offline
Ok thats such a broad question that I cant even begin to answer it.
Figure out what model you want, if it will be street legal, your budget, type of offroading, etc then we can better answer your question.
2000 XJ Classic - Classically a POS
1994 Isuzu Amigo XS -Sold
1972/3 CJ5 Glass body, 5" lift 34's. 5 years of work coming to an end.
Re: Looking for input about a body lift and tires [Re: Firecrotch] #808221 04/27/07 02:28 AM
F
Im still looking at jeeps, i guess just wrangler. i dont really know a lot about them what do you recomend? i definately want fuel injected. stick or auto, as long as its four wheel drive.
Re: Looking for input about a body lift and tires [Re: Firecrotch] #808222 04/27/07 03:45 AM
F
Fred Blackstone Offline
Terre Haute, Jeep Wranglers are a lot of fun but IMHO may not be a good choice for "muddin"! Yes, I'm a rock-solid Jeep fan, but let's be honest: Jeeps are light-duty off-road vehicles and are not designed for near continuous use in deep mud venues without significant modification and expense. IMHO, Jeeps come-up-short in the areas of horsepower, and tire-spinning drivetrain strength. My best recommendation would be to purchase a one-ton-rated pickup truck of the same era!
Re: Looking for input about a body lift and tires [Re: Fred Blackstone] #808223 04/27/07 04:27 AM
F
im not wanting to go hardcore mudding, just some light trails and shallow mud. i dont want to tear it up. i just have wanted a jeep for a long time. but i dont want it to just be for the road i want it to be able to go off road w/o problems.
Re: Looking for input about a body lift and tires [Re: Firecrotch] #808224 04/27/07 05:34 AM
F
Good! I'd recommend a TJ Wrangler (97-06) with a 6 cyl. engine. The older YJ Wranglers are not that great offroad or onroad compared to the TJ. Pretty much there is little you'll need to do to a TJ for trail use, it's been a very capable offroad and onroad Jeep right-off-the-show-room floor. Not much need for 35 inch or taller tires and stronger axles and gears, at least as long as you don't attempt crossing deep water and swamps, or traverse difficult rocky trails in the West. Some TJ's came with special purchasing packages having Dana 44 rear axles; this would be a plus if you could snag one.
Re: Looking for input about a body lift and tires [Re: Fred Blackstone] #808225 04/27/07 01:19 PM
DBL_DTY97TJ Offline
I'll 2nd that...Very capable stock. You wouldn't need mods at all really for reasonable stuff (by reasonable, I mean it can get pretty puckery!). But 33's are prolly about as big as you'd want to go with the tires w/out changing out the gears $$$. Easy to lift enough to fit 33's too, and they'll go pretty much anywhere. <img src="/forums/images/graemlins/cheers.gif" alt="" />
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: Looking for input about a body lift and tires [Re: Fred Blackstone] #808226 04/27/07 11:11 PM
F
ok, thanks guys. i really appriciate the help. would you recomend stick or auto? all i have driven is stick so im leaning towards an auto for somethin different.
Re: Looking for input about a body lift and tires [Re: Firecrotch] #808227 04/27/07 11:20 PM
BigJim Offline
I prefer auto for offroad adventures.. A lot smoother in
the stop and go's. And of course on the street auto is great too.
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6367 MB (Peak: 0.7600 MB) Data Comp: Off Server Time: 2026-07-13 11:49:44 UTC
