Engine Questions- Mitsu Monty, Pajero, Chrysler...
#808282
04/26/07 10:16 PM
I'm looking into buying a Mitsubishi Pajero from Japan and I need to know which, if any, engines are compatible. I hear that the Montero and the Pajero are interchangable. Do the diesel and gas engines use the same auto tranny? Are the 3.0 and the 3.5 Mitsu engines the same engines as in some of chryslers lineup- Chrysler Intrepid, Dodge Caravan...
Can anyone confirm this? I need options if the 2.5 turbo diesel pops and can't get a replacement. Thanks!
Re: Engine Questions- Mitsu Monty, Pajero, Chrysler...
[Re: DREJ]
#808283
04/27/07 12:12 AM
2.5 TD's don't pop <img src="/forums/images/graemlins/kewl.gif" alt="" /> You would still be able to get a replacement engine thru the many "low miles" engine importers so I think your covered.
You might get more info over on the Canadian board....I mean the diesel board <img src="/forums/images/graemlins/lol.gif" alt="" />
[Re: LRJ4x4]
#808284
04/27/07 09:01 PM
What?? Theres a Canadian board?? Oh come on.. its probably a west coast thing too, right?? Sheesh.. <img src="/forums/images/graemlins/smile.gif" alt="" />
Strangers have the best candy
[Re: DREJ]
#808285
04/27/07 09:54 PM
Thanks to the internet you can get any part u need. The mitsubishi 3.5 SOHC or DOHC are not the same as the new chrysler 3.5 V6. I'd also would recommend that you talk to the Canadian importers of JDM vehicles, eh? Or you'd spend thousands on something you can't title in the USA, you betcha.
83 mitsu flat bed 2.6l weber, 88 auto tranny, 2" body lift, 4.625 LSD, 235/85-16E mudders (33 x 9.50).
[Re: whitelespaul]
#808286
04/28/07 12:11 AM
The truck is titled and certified. Yes it's legal in Canada thanks to our 15 year and older exemption to imports.
Maybe I'm asking too many questions so I'll ask just one: Do the gasoline engines from the Montero bolt up to the transmission from the 2.5 turbo diesel? We're talking 4 cylinder to 6 cylinder, will it bolt up to the tranny? Who says yes? Who says no?
[Re: DREJ]
#808287
04/28/07 12:25 AM
older than 15 years...is that the only clue ? I dont know the answer, but I will read what others say.
I dont think so...but i dont know so.
1989 5 door montero 3.0 auto stock original Japanese about 200k miles
[Re: DREJ]
#808288
04/28/07 06:41 AM
Do the gasoline engines from the Montero bolt up to the transmission from the 2.5 turbo diesel? We're talking 4 cylinder to 6 cylinder, will it bolt up to the tranny? Both use a V5MT1 in manual config. Now I can't tell you for sure that it'll bolt up, since they may have retooled the bellhousing or something else to make it fit, but I guess you could theoretically swap those... What I can tell you is the gear ratios are different, and using the 2.5 TD behind the gasser trans may make it unusable, power band wise. Sorry I can't give you more, but unless I've seen it done, I don't want to speculate beyond giving you the numbers. ? <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> That's funny. <img src="/forums/images/graemlins/smile.gif" alt="" /> I do like it though. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: DREJ]
#808289
04/28/07 02:55 PM
From my research into this, I found at least 3 bellhouse patterns; man trans narrow for early 2.6 in Gen 1's, narrow auto trans pattern for 83 to 86 Chrysler 904 trans only, and later wide pattern for turbo (and Starion) motors in both man and auto (4 speed OD) forms. What I'm not sure of is whether the wide pattern non turbo 87 and up 4 cyl A/T is the same as the 3.0 V6 A/T pattern. All the 2.5 TD's have the wide pattern IIRC. The later trannys have electrical input from the ECU for the gas engine that may or may not work with a diesel ECU.
[Re: whitelespaul]
#808290
04/28/07 06:48 PM
Now we're getting somewhere! Does anyone know if the wiring harness for the diesel and the gas engines are the same. I wouldn't think so, but you never know what these engineers are capable of. Who wants to snap a pic of the 87 an up V6 bolt pattern and post it for us? I'm going to ask on the POCUK board for a pic of the 2.5. We can compare. I can't believe there is no list of tranny codes on this internet of ours. Thanks guys.
[Re: DREJ]
#808291
04/28/07 09:21 PM
wwwdriveline.com has trans numbers & configurations for different autos, I think ? Check it out.
"YOU CAN ONLY LEARN SO MUCH KNOWLEDGE IN A LIFETIME..BUT IMAGINATION IS WHAT MAKES THE WORLD GO AROUND" 89 POWER RAM D50 4X4 XCab 2.6L 91 Grand Prix GTP 3.4L 87 Jeep YJ Laredo 4.0L EFI
