is it worth it?
#808335
04/27/07 02:13 AM
I was wondering if anyone could help me please. My problem is im looking at buying an 89 trooper 2.6 auto and need to know what to look for and anything that i should avoid. I like the first gen troopers but cant at the moment afford nor do i have the place to buy a project vechile so any help would be appreciated.
Re: is it worth it?
[Re: Jackyl]
#808336
04/27/07 03:37 AM
Isuzu Moderator
The main thing to look for with the 2.6 are a blown head gasket and/or cracked heads. They are good engines if properly maintained.
Sean Strawmyer Back and ready to rock...... crawl. From Indiana or surrounding states and interested in wheelin'? Check out www.mwior.com
Re: is it worth it?
[Re: strawmyers]
#808337
04/27/07 05:10 PM
thank you man. as far as i can tell its fine except for some mild lifter clatter. again thank you
tread light and save our right '92 Rodeo 3.1 5spd full manual 4x4 w/ Aisin hubs '87 F-250 460 4spd full manual 4x4 granny low
Re: is it worth it?
[Re: Jackyl]
#808338
04/29/07 03:31 AM
Isuzu Moderator
Better look again. No lifters on this one.
Michael
Re: is it worth it?
[Re: mlclark]
#808339
04/29/07 03:56 AM
Isuzu Moderator
Probably hearing the fuel injectors. Those things are noisy on the 2.6 <img src="/forums/images/graemlins/oink.gif" alt="" />
Re: is it worth it?
[Re: strawmyers]
#808340
04/29/07 04:44 AM
Isuzu Moderator
Or loose valves...or an exhaust leak...or a leak in the air rail for the Smog pump....or....
m
Re: is it worth it?
[Re: mlclark]
#808341
04/30/07 12:17 AM
thanks for all the input guys but i didnt get the trooper. i instead found a 92 rodeo 3.1 5 speed for a lil more with nothing wrong so i bought that. again thank you all
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6173 MB (Peak: 0.6914 MB) Data Comp: Off Server Time: 2026-06-17 10:45:51 UTCValid HTML 5 and Valid CSS
