Starter sometimes spins?
#808386
04/27/07 04:11 AM
It started this winter. On cold mornings the starter sounded like it was not engaging the engine and was just spinning freely. I would let of the ignition and try again. Eventually it would catch just fine. Now it is happening again every now and then but the cold is not a factor. There is never any grinding, it sounds like there is no resistance and it spins fast. Should i replace it before i get stranded?
Thanks, <img src="/forums/images/graemlins/cheers.gif" alt="" />
86 CJ7, 258, MC2100 Carb, 4" Rough Country lift, 34" Swampers, Jeeperman bumper/tire carrier
Re: Starter sometimes spins?
[Re: Thord]
#808387
04/27/07 04:32 AM
The "spinout" part of the gear assembly on the starter is dirty! You can take it apart and give it a good cleaning.. New ones are available but are near the cost of a complete rebuilt starter. Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: BigJim]
#808388
04/27/07 12:10 PM
Thord...yes, it sounds like the bendix is not popping out and engaging the flywheel like it should. I would check all of my connections first...if those are good I'd just replace the starter. They're under 100$ and 2 bolts are all that holds her up there! I've replaced my starter twice...the first was the original and the second was a remanufactured that lasted a whole 2 weeks.
[Re: 93yj]
#808389
04/27/07 07:45 PM
This just happened to me a couple months ago! Bendix was sticking. A rebuilt starter at auto zone is pretty cheap. It will jump right in there and you prbably wont have to worry about it for another 15 years
Josh
80 CJ-7. It runs
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.5995 MB (Peak: 0.6550 MB) Data Comp: Off Server Time: 2026-07-13 04:54:38 UTCValid HTML 5 and Valid CSS
