Weber carb swap 32/36 DGEV vs 38 DGES #808395 04/27/07 05:29 AM
manthis Offline OP
My tropper is a 87 2.3L 4cyl, engine block has been rectified and all valves and seals replaced.
I am looking for a replacement of the stock carb.
After some research it seems that the way to go is a for a Weber conversion, but I would like to get some input in regards emissions (considering that the engine has been overhauled) since the vehicle is mainly for street use purposes.
It also seems that the weber carb will provide better mileage but I would appreciate your input as well.
And finally, it seems that the right conversion kit for the 2.3L is the WK697 (32/36 DGEV) as listed on weber's site:
http://www.webercarburetor.net/product.php?productid=16151&cat=261&bestseller
And Indy4x:
http://independent4x.com/item.jhtml?UCIDs=839915%7C1016331&PRID=1111818
But there's also the WK697-38 (38 DGES)
http://www.webercarburetor.net/product.php?productid=16152&cat=261&bestseller
Which seems to fit the 2.3L as well, there is also a considerable difference in price, so I'm wondering if anybody out there could provide some insight on the differences.
Thx in Advance!
Re: Weber carb swap 32/36 DGEV vs 38 DGES [Re: manthis] #808396 04/27/07 08:05 PM
Trooperfreak Offline
I've been running the 32/36 DGEV for years. I bought it from National Carburetor in Jax for about $275.00 with a core. They suggested that I go with the 32/36 rather than the 38. You will not improve your mpg, at least from my experience...but the power increase over the Hitachi was noticeable. (I converted a 2.6 from FI to carb)
Good luck
'86 Isuzu Trooper II, Durabak coated exterior, 4ZE1 2.6L, Weber 32/36, K&N, Rancho RS9000, Indy4X shackles, BJ flip/T-bar crank, Pacesetter header, dual core radiator, Mazda seats, 31x10.5 BFG TAKO's
Re: Weber carb swap 32/36 DGEV vs 38 DGES [Re: manthis] #808397 04/28/07 07:53 PM
Trooper-san Offline
Be sure about the legality of changing carbs. Here in California a Trooper with a Weber carb would not pass smog. It might run better, it might run cleaner, but it would not pass smog because it is nor OEM.
I went through this with a '73 VW camper. It stock condition it had 2 single barrel carbs. I replaced them with a single 2bbl Weber, a 32-34 DGEV, and it ran so much better, with alot more power. I had to remove the Weber every second year and put the OEM carbs back on for the smog test.
Other than that, the switch was the best thing I ever did to the camper.
1989 Trooper, 2.6
1989 Trooper, 2.8
1992 Ford F-350, 7.3
My Photos
Re: Weber carb swap 32/36 DGEV vs 38 DGES [Re: manthis] #808398 05/03/07 01:39 AM
blevcom21 Offline
i have weber carbs on both of my carbed 4x4s and i love them check your local emissions laws first but other than that go with the weber 32/36
if it don't fit, force it if it breaks, it needed to be replaced anyway
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6056 MB (Peak: 0.6628 MB) Data Comp: Off Server Time: 2026-06-07 09:08:09 UTC
