Top end rebuild or am I in for the whole nine yards. #808400 04/27/07 06:05 AM
DangerCart Offline OP
Drivers side camshaft seized in my truck.I have already obtained a replacement head out of a 91 chrysler lebaron.I took the whole assembly and from my understanding there should be no difference please correct if I am wrong.
My truck is a 1989 Dodge raider 3.0 with a 5-speed. The mileage is just over 160,000. Heres my plan because I really like this truck, Is to fix up both heads(recomendations on how to do so?)and clean up the top end parts.
1989 Dodge Raider 3.0L with 5-speed.
In limbo of what to do with it.
Re: Top end rebuild or am I in for the whole nine yards. [Re: DangerCart] #808401 04/27/07 07:52 AM
LandRaider Offline
No help on 3.0 from me, but I like your username. smile
Re: Top end rebuild or am I in for the whole nine yards. [Re: LandRaider] #808402 04/27/07 11:45 AM
Y
yankneck696 Offline
I would go for both heads off of the same vehicle. Even if it's the same cam as the monty, there will be a different ammount of wear. That situation will give the possibility of an unbalanced fuel/air distribution & poor running. I would also not use the other cam from the caravan in your head, as machining tolerances may be too tight ow just sloppy.
Ed
Yankneck = Yankee ingenuity with Redneck stupidity.
"How can I break it better?"
89 Raider 3.0 w/ 31's for now
Re: Top end rebuild or am I in for the whole nine yards. [Re: yankneck696] #808403 04/28/07 06:48 AM
Chances are the car that I got the head from may not be there. When I picked the vehicle to tear apart I selected one with similar mileage and made sure everything turned freely. If need be i'll replace both cams. Would the roller rocker assembly affect cam timming?
Re: Top end rebuild or am I in for the whole nine yards. [Re: LandRaider] #808404 04/29/07 02:05 AM
Thanks.
I like what you've done with your truck. I take it yours was originally a 4-banger?
Re: Top end rebuild or am I in for the whole nine yards. [Re: DangerCart] #808405 04/29/07 03:24 AM
FrankR Offline
Chrysler changed to roller rockers in '90 for the 3.0L Caravan engines. The Montero/Raider 3.0L engines had roller rockers from the beginning in '89. So, as long as you have '90+ Caravan heads, there should be no difference in the valve train - just swap some Montero/Raider cams into the Caravan heads.... but at least check the cam bore clearances.
You may need a couple of longer bolts for the valve covers.
Frank
Re: Top end rebuild or am I in for the whole nine yards. [Re: FrankR] #808406 05/19/07 07:02 AM
If I do the top end am I asking for trouble on the lower end?
Re: Top end rebuild or am I in for the whole nine yards. [Re: DangerCart] #808407 05/19/07 10:48 AM
FrankR Offline
It's hard to say unless you do a compression test.... but to do that, you need to have the heads on the engine and the cams working. If the engine was ok before the cam seized, you could try just rebuilding the heads.... but the main question is "Why did the cam seize?". Lack of lubrication could be from a bad oil pump or insufficient oil quantity - both of which could also have damaged the rod bearings.
Frank
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6229 MB (Peak: 0.7210 MB) Data Comp: Off Server Time: 2026-11-03 13:34:43 UTC
