LSD noise? #808703 04/29/07 05:50 PM
89montero Offline OP
My 89 lwb has the stock LSD if the back and when I accelerate around a turn it usually makes a weird vibration. I figured it was just the limited slip slipping or one of the tires scuffing but was told that it isn't supposed to do that. I don't know when the fluid was last changed on it.
Any info on this?
1989 Montero 4dr V6 3.0l
Re: LSD noise? [Re: 89montero] #808704 04/29/07 07:41 PM
As you accelerate in a corner, the LSD tries to spread the torque to both wheels. In a turn, the outer wheel has to make up more distance on the outside radius, and the torque spread through the LSD transfers a similar rotation to the inside tire = scuff, chirp, etc. Happens all the time with my Raider. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: LSD noise? [Re: rxinhed] #808705 04/30/07 01:07 AM
hotdogx3 Offline
My 1989 LWB does the same thing; IÆd say itÆs supposed to do that. Those vibrations mean that the LSD is working properly. <img src="/forums/images/graemlins/cheers.gif" alt="" />
1989 Mitsubishi Montero LWB, Superwinch Manual Hubs
Re: LSD noise? [Re: hotdogx3] #808706 04/30/07 01:16 AM
TXrazor Offline
vibration = traction <img src="/forums/images/graemlins/kewl.gif" alt="" />
91 Montero SuperWagon LWB, Pro Comp Xterrains, Blk Steel RockCrawlers, Aisin Locking Hubs, Pro Comp 9" HID Lights, Projector H4 Headlights, ARB Bull Bar, K&N, Alpine, Optima and a Hella loud Hella Horn... More to come!!!
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6022 MB (Peak: 0.6580 MB) Data Comp: Off Server Time: 2026-11-16 08:40:07 UTC
