No Spark #808739 04/30/07 01:50 AM
A
antheil Offline OP
I am working on my son's 94 Cherokee with no spark. I have changed the coil and the distributor is only a year old. I don't see an ignition control module û what else can I check?
Re: No Spark [Re: antheil] #808740 04/30/07 02:02 AM
BobRowe Offline
Is the ground to the coil going on and off, as it should, when you crank it? Is the ignition fuse OK?
Re: No Spark [Re: BobRowe] #808741 04/30/07 02:06 AM
A
antheil Offline OP
Yes - I checked it with a test light and it goes on and off slowly - It does not blink quickly û is that right?
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5909 MB (Peak: 0.6434 MB) Data Comp: Off Server Time: 2026-06-22 01:14:19 UTC
