Re: Brake Troubles [Re: BigJim] #808800 05/07/07 02:15 AM
harveythound Offline OP
Please describe what you mean by the ZACT highest point of them? Thanks.
Re: Brake Troubles [Re: harveythound] #808801 05/07/07 03:40 AM
BigJim Offline
The word is Texan for "exact"...
Meaning if the calipers are on the WRONG side of the vehicle the bleeder will NOT be exactly on the top and there is some AIR above the bleeder that CANNOT be squirted out! The ones that have been brought to me required 3 or 4 pumps to compress all the air... just like you describe.
They come in a box marked "left" or "right" If they are backwards the problem exists ZACKLY as you describe..
Re: Brake Troubles [Re: BigJim] #808802 05/07/07 05:48 AM
BlueXJ Offline
I am by no means an expert but had an old chevy that had similar symptoms and it turned out to be a bad booster. Changed it and had great brakes again.
90 XJ 4.0L 3.5RE on 31s 242 SYE 12K MM winch
Re: Brake Troubles [Re: harveythound] #808803 05/07/07 11:31 PM
F
ffountain Offline
1981 CJ7 - I have just done a complete brake job, replacing drums, piston, rear shoes, front pads, rotor, and calipers. Before the brake job I couldn't get a good pedal when bleeding the brakes and I still have the same problem. When I bleed the brakes there appears to be no air coming out of each wheel?
Does anyone know whether I just can't get all air out of the system or have a small hole somewhere in the system?
Please give your suggestions.
I had a similar problem and a buddy suggested that my emergency brakes were not working allowing my rear shoes to pull in to far from the drums. We adjusted the E-brake cable and then I had no problem bleeding them. I might add I had replaced the complete system except for the proportioning valve.
Re: Brake Troubles [Re: BigJim] #808804 05/19/07 03:20 PM
hlhneast Offline
I dunno about Harvey, but I am gonna double check mine to make sure to prevent this problem. My system is completely brand new except the proportion block. Thanks for the tip, Jim. <img src="/forums/images/graemlins/kewl.gif" alt="" />
77 fiberglass CJ-7 304, Ground up Resto-mod Edelbrock Air Gap, Holley 1850, Headers and Flowmasters, Black Diamond suspension, BFG 33X9.50 on Outlaw I's. Hopefully on the road this year!
Re: Brake Troubles [Re: hlhneast] #808805 05/19/07 04:14 PM
BigJim Offline
He ain't been here in 13 days....I wonder how this turned out?
Re: Brake Troubles [Re: BigJim] #808806 05/19/07 04:19 PM
Brown81CJ5 Offline
I sure hope his brakes aren't the reason he hasn't been back in a while. <img src="/forums/images/graemlins/scared.gif" alt="" />
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: Brake Troubles [Re: BigJim] #808807 05/20/07 03:49 AM
hlhneast Offline
He either fixed it or is in the hospital from when he slid thru the stop sign (jeez, just joking, hope everything is ok!). I am pleased to report I managed to get my calipers on right, as I remember there really was no other way to put em on to make the hose work out too.
Re: Brake Troubles [Re: BigJim] #808808 06/02/07 06:55 AM
You Da Man Big Jim.
The previous owner had two left calipers on the jeep, which was part of the confusion. Switching the new rebuilt calipers to ensure the valves were allowed the brakes to bleed, but was different set-up than was previously on the brakes. In addition, the brake lines are now attached near the middle of the brakes--so the doesn't stretch and won't break. Back in the dirt tomorrow!!!
Thanks for all input!!!
<img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Brake Troubles [Re: harveythound] #808809 06/02/07 04:05 PM
BigJim Offline
Thanks Harvey... Sure took a while to get around to them calipers. Glad you (or someone) finally checked them.
HMMM only one on the wrong side, huh? That's the first time I have had that problem occur... Seems like the guy that put it on there would have had some inkling that he had just created a new problem don't it.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6367 MB (Peak: 0.7622 MB) Data Comp: Off Server Time: 2026-05-29 19:58:03 UTC
