What does this thingamajig do? #808810 04/30/07 06:11 AM
P
Poor A$$ Stock '93 Offline OP
I just replaced my power steering pump today. Sure is nice to have that back. Anyway when I was in there I noticed that the little plastic pod on the bottom that has a couple vacuum lines off of it was broken. The plastic nipples for the lines were broken off. Steering seems to work fine again with out it so I was wondering what this piece does?
North Caribou Offroad Adventurers Society
www.offroad.bc.ca
Re: What does this thingamajig do? [Re: Poor A$$ Stock '93] #808811 04/30/07 07:36 AM
Davepet Offline
A picture would be helpful, but sounds like it might be a pressure switch that bumps up the idle a bit when the power steering pressure gets above a set value.
Re: What does this thingamajig do? [Re: Poor A$$ Stock '93] #808812 04/30/07 01:03 PM
Peli Offline
that is a vacuum switch that idles up the motor when turning the wheel just make sure the lines are capped or they will suck in crap into your intake
1989 toyota 4runner 5speed 4" lift
Re: What does this thingamajig do? [Re: Peli] #808813 04/30/07 04:30 PM
dcg9381 Offline
Anyone know the correct threads to cap this thing with?
22REturbo.net
1988 4Runner
Re: What does this thingamajig do? [Re: dcg9381] #808814 04/30/07 05:29 PM
1
1FastSS Offline
Just RTV over the vacuum lines and away you go.....unless it's a show truck, then pull the switch and go get a brass plug..... <img src="/forums/images/graemlins/smile.gif" alt="" />
- Daily Driver - 2004 Corolla
- Off Road - 1992 Pickup SR5 3.0L 4x4
- Fun - 2001 Camaro SS (320 RWHP/330 RWTQ)
http://community.webshots.com/user/1fastss
Re: What does this thingamajig do? [Re: Peli] #808815 05/01/07 02:55 PM
OOP'S Offline
I would be more worried about the engine running rough and burning valves then sucking crap into the engine.
It is an "idle up" valve for when the PS is working hard like at lock so the engine will not die. I found where the two lines go into the intake. I removed one and looped the other into it place. As far as a plug, I had to plug off the valve hole. I tried the RTV but mine was leaking fluid so I removed it, broke the plastic off, and brazed up the hole. If you do not have access to a find a metric thread brass plug for it. Do not try a metric bolt, it is a metric tapered pipe thread.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: What does this thingamajig do? [Re: OOP'S] #808816 05/01/07 07:07 PM
1
1FastSS Offline
I would plug the 2 lines in the manifold. If you loop one to the other, won't it be on high idle since the line will be open?
Re: What does this thingamajig do? [Re: 1FastSS] #808817 05/01/07 07:20 PM
4Crawler Offline
Yep, you need to cap the un-used lines:
If looped (and not plugged) the vacuum at the idle up valve will open it and bump up the idle speed (that is a good way to test the idle up valve BTW):
http://www.4crawler.com/4x4/CheapTricks/22RE_Engine_Pix/index.html
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6249 MB (Peak: 0.7241 MB) Data Comp: Off Server Time: 2026-06-17 13:25:33 UTC
