Landcruiser HJ61 axle strength ??? #808866 04/30/07 03:07 PM
7
777 Offline OP
I plan doing a SAS and also rear axle swap on my Dodge Raider V8 (386 hp, 397 lb*ft). At the moment I'm using 33" tires and original axles..., but this combination is killing half-shafts too often...
One option is to use Landcruiser HJ61 axles with lockers. Would these axles survive? I plan using 35"-38" tires.
Does anyone know the ring gear diameter, half-shaft diameter at spline and weight of axle?
Raider 6.0 V8 386hp, 397ft lb, 3?exhaust, Megasquirt ECU, EDIS ignition, Innovate LC-1 WB Lambda, NV4500, NP241 with JB conversions ?super short? SYE kit
Re: Landcruiser HJ61 axle strength ??? [Re: 777] #808867 04/30/07 11:12 PM
ClarkGriswold Offline
Check out ih8mud.com for all your fj needs.
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5882 MB (Peak: 0.6361 MB) Data Comp: Off Server Time: 2026-06-07 06:02:51 UTC
