Transfer case rear seal leaks #809019 05/01/07 04:48 AM
fleetbob1 Offline OP
Since i put A rear locker not (lsd) ive had a leak at the rear transfer case seal Iv;e tried 4 differnt seals but they all leak!!!
Is the drive shaft longer for the lockers ?
It looks like it needs to be.
there is no wear in the rear output shaft bearing or the extension housing bushing.
Has anyone experienced this before? 1990 LWB 5SP 3.0--LIFTED
1990 Montero LWB V6 5-SP Locked Rear/33/12.50 Kumho KL-71 Mud Terrains/3" body lift,bars/springs/poly/shocks/custom skids/lots of lights/snorkle/etc......
Re: Transfer case rear seal leaks [Re: fleetbob1] #809020 05/01/07 04:56 AM
52degrees Offline
Yep. Mine leaks too. Tried a new seal and a second ext. housing.
The good news is it doesn't leak a whole lot.
KG6VNX
Re: Transfer case rear seal leaks [Re: 52degrees] #809021 05/01/07 05:16 AM
justice Offline
Drive shaft yoke may be worn. sometimes a groove gets worn into the yoke and will leak even with a new seal. Did you swap in a locker from a gen 2?
Re: Transfer case rear seal leaks [Re: justice] #809022 05/01/07 09:52 PM
Tag Offline
This happened to me as well. Finally I noticed that a cap in the center of the driveshaft yoke was missing. Had a piece of metal welded over it and it no longer leaked. To see the cap you can try to look through the ujoint into the back of the yoke. If you can see in the yoke it is missing.
89 2dr 3.0 AT, manual hubs. 33x12.5 MT
gen 2 coils,Cranked front tbars
Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
Re: Transfer case rear seal leaks [Re: justice] #809023 05/02/07 03:29 AM
No Gen 1 out of a 1991 LWB LS
Ill take another look at the yolk
You may be right !!!!!!!!!!!!!!!!!!!!!
Re: Transfer case rear seal leaks [Re: fleetbob1] #809024 05/02/07 11:35 PM
Nope, the plug is intact
there is play in the splines so the yolk moves up & down just a little, causing the seal to leak.
Any suggestions?
Re: Transfer case rear seal leaks [Re: fleetbob1] #809025 05/03/07 03:38 AM
justice Offline
if the wear is in the splines of the yoke replace the yoke.
Re: Transfer case rear seal leaks [Re: justice] #809026 05/04/07 02:00 AM
I wish!!!!!!!!!!!
the wear is on the output shaft
I guess i;ll just live with it for now
Cause soon I'll be Ford powered !!
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6252 MB (Peak: 0.7072 MB) Data Comp: Off Server Time: 2026-11-17 11:23:49 UTC
