Page 1 of 3 1 2 3
What can be done to free up intake and air flow? #809174 05/02/07 03:23 AM
allsierra123 Offline OP
I just got a cherry bomb pro muffler and 2 1/2" exhaust with a free flow cat.So Im wondering what I can do on the other end to open it up on the other end.The muffler sounds awsome.Makes it sound like a 3000gt.Oh yeah its a 3.0 12v.
91 Mitsu Montero RS LWB PENDING
88 Cherokee Lifted and modded heavily. FOR SALE
91 vanagon syncro 1.9 TD SOLD
04 Suzuki Aerio Commuter SOLD
90 mits mighty max,v6 SOLD
94 Mits Diamante LS. Stock. TOTALED
71 VW Baja Bug SOLD
Re: What can be done to free up intake and air flow? [Re: allsierra123] #809175 05/02/07 03:42 AM
fleetbob1 Offline
Get Rid of any turbulance in the intake hose
cut out the bellows and install straght pipe
use a K&N air filter if thet make one
1990 Montero LWB V6 5-SP Locked Rear/33/12.50 Kumho KL-71 Mud Terrains/3" body lift,bars/springs/poly/shocks/custom skids/lots of lights/snorkle/etc......
Re: What can be done to free up intake and air flow? [Re: fleetbob1] #809176 05/02/07 03:51 AM
52degrees Offline
They do make one.
Don't do it. Trust me, I'm a professional. <img src="/forums/images/graemlins/shame.gif" alt="" /> <img src="/forums/images/graemlins/shame.gif" alt="" /> <img src="/forums/images/graemlins/shame.gif" alt="" />
KG6VNX
Re: What can be done to free up intake and air flow? [Re: allsierra123] #809177 05/02/07 04:13 AM
FrankR Offline
This opens up the intake side of a 3.0L pretty good..... maybe a little too good if you aren't careful:
Frank
Re: What can be done to free up intake and air flow? [Re: FrankR] #809178 05/02/07 04:20 AM
52degrees Offline
Frank, that is truley a thing of beauty.
Is it a driver yet?
KG6VNX
Re: What can be done to free up intake and air flow? [Re: allsierra123] #809179 05/02/07 05:02 AM
TXrazor Offline
I have a K&N, seems to work well. You could get the 3.5 t-body from a newer model Montero, should help it "breathe" a little bit better.
So how loud is that muffler? I'm lookin' into something aftermarket with a better tone. But, don't want any of that crazy loud noise. <img src="/forums/images/graemlins/lol.gif" alt="" />
91 Montero SuperWagon LWB, Pro Comp Xterrains, Blk Steel RockCrawlers, Aisin Locking Hubs, Pro Comp 9" HID Lights, Projector H4 Headlights, ARB Bull Bar, K&N, Alpine, Optima and a Hella loud Hella Horn... More to come!!!
Re: What can be done to free up intake and air flow? [Re: 52degrees] #809180 05/02/07 05:04 AM
They do make one.
I'm not a pro but IMHO I definitely concur with his statement all day long.
Here's why... A K&N will let more air flow but at the expense of allowing more particulate matter in too (no it doesn't trap more dirt because it uses "stickier" oil.
More particulate matter means more dirt into your intakes/engine which means more wear on the engine which = more rebuilds which = a bad idea, especially off road.
HTH.
Re: What can be done to free up intake and air flow? [Re: off-roader] #809181 05/02/07 05:14 AM
TXrazor Offline
<img src="/forums/images/graemlins/frown.gif" alt="" />
Re: What can be done to free up intake and air flow? [Re: 52degrees] #809182 05/02/07 05:18 AM
G
generation_one Offline
They do make one.
What he means is...er, what I do is this:
1.Remove the paper filter and button the canister back up.
2.Slide the intake breather off the throttle body.
3.Stretch some panty-hose over the throttle body intake.
4.Put the breather line back on.
...not really.
1989 5 door montero 3.0 auto
stock original Japanese
about 200k miles
Re: What can be done to free up intake and air flow? [Re: generation_one] #809183 05/02/07 05:32 AM
don Offline
...more airflow?
More airflow than what?
You need to supply a 3.0L with lots of clean cool air, and the Mitsu can-filter on the 3.0 does exactly that. It's a 3" system, with a huge filter, taking cooler cleaner air from in the fender, it's more than enough. In fact it works so well, I transplanted the whole intake/filter from a Mitsu 3.0 into mine and use it to supply a 4.3L engine (with a 3" exhaust).
I got no airflow issues.
Why should you?
Don `87 Mitsu 2dr, Rubicon survivor, GModified.
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.012s) Memory: 0.6414 MB (Peak: 0.7670 MB) Data Comp: Off Server Time: 2026-07-17 00:46:59 UTC
