convert electric window to manual #809248 05/02/07 08:21 AM
rednekbean Offline OP
so the girlfriend has a 86 x-cab sr5. her driver side window would roll down but it would not roll up all of a sudden one day. so i pull the switch cluster out of the door, noticing it has been rigged once already, and i determined the switch was bad and just jumped the motor to get it to roll up.
now for the question....is there a way to take the electric crank out and make it a hand crank on the window's with out just finding door's with manual locks and windows?
that and the key she got with the truck works in the ignition, which is a given with those ignitions, but the key does not work in the door lock. so if any body has door locks and the matching key for a 2nd gen send me a message.
nick
92' Pick-up, SAS, gears to make her crawl, 37's , bullet proof motor, and alot of time invested.
06 CRF450R one mean roost flinging machine
Re: convert electric window to manual [Re: rednekbean] #809249 05/02/07 11:28 AM
foxtrapper Offline
Sure. The basic mechanism is the same, the factory merely replaced the hand winder and spring with a motor.
Easiest way is to go to a junkyard and remove the winder assembly. Bolt in swap.
Don't forget the door panel. You're going to have to punch a hole in the existing one, or pull one from a junkyard.
Why not simply fix/replace the electric switch?
'97 T-100 SR5
Re: convert electric window to manual [Re: foxtrapper] #809250 05/02/07 03:49 PM
sirus027 Offline
would it be easier to just swap out the doors?
I was thinking I want to go back to having the manual myself (and the beloved wing window for instant blast of air...and bugs). Would have more room too for bigger speakers in the door panel.
Re: convert electric window to manual [Re: sirus027] #809251 05/02/07 04:09 PM
Bustedback Offline
I just swapped out the rigged powered window regulators for manual windows in my 86. It is very easy to do, just pull out the electric regulators and bolt in the hand crank regulators, but you will have to do something about the door panels. I was able to find the passenger side with no problems at the boneyard, but the driver side was very hard to find at the boneyard. I'm not sure how much a new regulator would be.
Re: convert electric window to manual [Re: Bustedback] #809252 05/02/07 04:54 PM
dewmtndew Offline
man, I want to go to power windows. I didnt realize everybody was going the other way. I figured all the bolts were the same, but how different are the door panels? Any body wanna trade?
erick
85 Pickup
33s, lift, EB cam, header, exhaust...
Re: convert electric window to manual [Re: rednekbean] #809253 05/02/07 05:32 PM
4Crawler Offline
It is usually possible to repair the switch:
http://www.4crawler.com/4x4/CheapTricks/index.shtml#WindowSwitch
Re: convert electric window to manual [Re: sirus027] #809254 05/02/07 06:38 PM
foxtrapper Offline
You can have power windows and the vent window. The basic winder mechanism is the same for both types, just a single bar added to the wide window units.
'97 T-100 SR5
Re: convert electric window to manual [Re: foxtrapper] #809255 05/02/07 06:47 PM
ToyotaT Offline
Ditto on the trade. Anyone up for it let me know....I'm too dern lazy to want to roll mine up by hand in the small cab of my Toy.
T.
85 Toy Pickup
89 block 30 over and EB RV head/261 cam
Re: convert electric window to manual [Re: foxtrapper] #809256 05/02/07 08:55 PM
yes i know how to fix the switch, it is a simple contact problem just like you had on your pass switch 4crawler. The only reason i was curious about the swap was because i really just didnt want to have to fix the thing every time she pushes to hard or slams her door hard, not to mention the various small leaks around the cab, mixed with her trying to keep up with my truck on the dunes or out in the woods.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6269 MB (Peak: 0.7298 MB) Data Comp: Off Server Time: 2026-10-21 22:05:59 UTC
