Towing Capacity of a Cherokee? #809599 05/03/07 10:08 PM
W
wgripp Offline OP
Allright, so the CJ idea got scratched. Would a Cherokee make a good tow rig?
I'm looking at a 6cyl with a 5 inch lift. Is it still possible to mount a trailer to it, considering the frame is not much higher off the ground?
Re: Towing Capacity of a Cherokee? [Re: wgripp] #809600 05/03/07 10:10 PM
BigJim Offline
I don't think the cherokee has a frame..
Re: Towing Capacity of a Cherokee? [Re: wgripp] #809601 05/04/07 01:13 AM
BobRowe Offline
It depends on how much you want to tow, what springs you have on the Cherokee, and what axle gears you have.
Also, BJ is right -- the Cherokee does not have a frame -- it is unibody construction.
Re: Towing Capacity of a Cherokee? [Re: BobRowe] #809602 05/04/07 03:35 PM
A
antheil Offline
Cherokees are a little short, longer wheel base vehicles are more stable. other than that it should be ok for a short lighter trailer
Re: Towing Capacity of a Cherokee? [Re: wgripp] #809603 05/04/07 04:53 PM
DBL_DTY97TJ Offline
IF you go with the lifted Cherokee, get a ball hitch that drops enough to keep the trailer level, or close to it. Don't know the capacity. The manufacturer should have a recommended "not to exceed" limit, but of course they play it very safe. <img src="/forums/images/graemlins/cyclops.gif" alt="" />
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: Towing Capacity of a Cherokee? [Re: DBL_DTY97TJ] #809604 05/04/07 05:27 PM
BobRowe Offline
Also, keep in mind that if you exceed the manufcturer's specified limit, and subsequently get in an accident, your insurance company may decline to cover the accident. Not to mention the basis that it may give the other party for pressing a lawssuit.
Re: Towing Capacity of a Cherokee? [Re: BobRowe] #809605 05/04/07 08:09 PM
W
wgripp Offline OP
Thanks guys
I wanted to tow a trailer with a 3,300 lb car on it. I guess the cherokee wont hold up
Re: Towing Capacity of a Cherokee? [Re: wgripp] #809606 05/04/07 09:14 PM
BigJim Offline
Yeah it won't last long. AND it'll not like the stopping either. MAke sure you have brakes on any 2 ton towed vehicle.
Re: Towing Capacity of a Cherokee? [Re: BigJim] #809607 05/04/07 09:15 PM
BigJim Offline
The reason for the brakes is because you may, sometime in the future, be behind ME!
Re: Towing Capacity of a Cherokee? [Re: BobRowe] #809608 05/07/07 06:05 PM
DBL_DTY97TJ Offline
Just as a side note to this, I once tried to rent a small trailer for my TJ from Uhaul. They would not rent it to me because it was not considered safe. Can't remember why exactly...
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6342 MB (Peak: 0.7409 MB) Data Comp: Off Server Time: 2026-06-23 01:16:57 UTC
