Best clutch? #809787 05/05/07 12:22 AM
P
PETE_YK Offline OP
I tested the clutch in my '88 22re pickup by trying to start off in 5th gear and instead of stalling she just spun and reved up. And it tends to spin under hard acceleration anyway and it is the orig. Freeplay is perfect. So, new clutch?... What are some good clutch kits out there? Should i just bite the bullet and go toyota? Dont wonna cheap out here, as buying a cheap clutch kit is not good. Should i consider replacing the slave cyl as well? (already has new-ish master cyl) Thanks.
88' Xtra cab, 22RE, 5 spd, alumi flat deck, 3" BL, 35" muds...awaiting SAS.
'02 Ram, 4.7, REV 'Shooter' wheels wrapped with M.T. Baja claws.
Re: Best clutch? [Re: PETE_YK] #809788 05/05/07 01:51 AM
4Crawler Offline
For aftermarket, Luk clutches are decent, Marlin Crawler's Heavy Duty clutch kits are supposed to be very good. I run a Centerforce Dual Friction clutch and it is still going strong after 9 years. Can't hurt to change out the slave, although my '85 slave is likely the original (I carry a spare one). Also change throwout and pilot bearings.
Re: Best clutch? [Re: PETE_YK] #809789 05/05/07 04:17 AM
G
Greg_Canada Offline
I'm very happy with my marlin. doesnt slip at all and all oem or better parts.
And yes replace the slave, i didnt and 1.5 years later i have too.. if i did it before i would have to worry about it...
89 4Runner
Re: Best clutch? [Re: Greg_Canada] #809790 05/05/07 03:44 PM
Dok Offline
I've got 30k on my Luk pro gold and I'm very happy with it. It's take a few beatings--couple of offroad trips and towing some stuff including my Supra and has held up well.
'87 4-Runner--DD/wheeler, 4.3 swap coming soon
'89 Supra--E85 powered 2jz NA-T Swap, 533rwhp 497ft-lbs
'89 Festiva, turboed BP swap powered by megasquirt
Re: Best clutch? [Re: Dok] #809791 05/05/07 04:40 PM
N
norcalsvx Offline
the marlin was a little to harsh for me i went with the centerforce and it is working great for me
1994 toy 22re
Engbldr. street rv head 261c,LC header,Downey dualshocks, BJ spacers, OME torsions, 33x10.50 BFG muds budbuilt xmember/skid plate 4.88's locker custom exhaust
2006 Subaru Forester XT
1994 Subaru SVX
1979 Mazda rx7
Re: Best clutch? [Re: norcalsvx] #809792 05/07/07 04:16 AM
mqm Offline
1989 Toyota 4WD extcab 22RE 132k 32x11.5 4.88 diffs
What kind of centerforce clutch are you using? My clutch is stock and is showing the first signs of slipping. Ive been debating on getting either a stageII or a dual friction cenetrforce clutch . Also thought about LC's HD clutch kit, but im leaning more towards the dual friction clutch. My truck is a daily driver but also does some 4 wheelin on the weekends. 4 crawler, is your dual friction clutch pretty well suited for daily driving also?
Re: Best clutch? [Re: mqm] #809793 05/07/07 04:34 AM
OOP'S Offline
Been running a CF I for over ten years and it has been beat on. Still working great.
Make sure to have your flywheel re-surfaced, even if it looks fine, re-surface it.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Best clutch? [Re: PETE_YK] #809794 05/07/07 09:11 AM
X
xTOYOTAx Offline
Sorry to hijack you but what are the diffrent from master cylinder and slave cylinder? are they both the same? I ask because the guy that I bought the 5 speed transmission only give me the cylinder that is next to the brake cylinder, so is that the master cyl or what? Im new to this stuff, get me confusion. So where can I locate the master cyl and slave cyl at? I have the 3vze.
Re: Best clutch? [Re: xTOYOTAx] #809795 05/07/07 01:56 PM
OOP'S Offline
MC is the one on the firewall, slave cylinder is the one on the bellhousing.
David Fritzsche
Roseville, CA
Re: Best clutch? [Re: OOP'S] #809796 05/07/07 03:08 PM
gueroblanco Offline
this is the last place i would expect people to be dicussing s&m... <img src="/forums/images/graemlins/scared.gif" alt="" />
<img src="/forums/images/graemlins/lol.gif" alt="" />
'95 runner 3vze/r150f
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6387 MB (Peak: 0.7629 MB) Data Comp: Off Server Time: 2026-10-24 07:32:15 UTC
