spacer under the carb #809834 05/05/07 04:04 AM
cktoy Offline OP
I see spacers advertised for throttle bodies and carbs that claim an increase in power.I have a friend with a mach shop that I think could cut me one out of alum. if I provided the patern.Would this be worth while?
oh what a feeling:
#1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered
#2 86 sr5 4x4 efi parts truck
#3 87 2wd parts truck
84 supra yard art
Re: spacer under the carb [Re: cktoy] #809835 05/05/07 04:10 AM
JackKnife Offline
The throttle body spacers are snake oil.
But, if you really want to have a spacer made, then how about making it 3 feet thick so you can use it like a snorkel? <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: spacer under the carb [Re: JackKnife] #809836 05/05/07 04:22 AM
xrtim Offline
Or maybe you could get one of those turbo tornado things that spin the air up as it goes down the intake. I've got friends who swear by them but I just can't bring myself to accept thier reality. <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: spacer under the carb [Re: cktoy] #809837 05/06/07 01:58 AM
foxtrapper Offline
Spacers under a carburetor are a very real, and very old, tuning technique. They create or enhance a plenum, which changes the signal or pulses the the carburetor sees. Almost always this works on the top end, at the expense of bottom end performance. It's not typically something you want on an off road crawler.
With throttle bodies, there is no venturi in front of the throttle blade(s), so it shouldn't make any difference. That said, sometimes it does. Don't know that it will on a Toyota engine, particularly an R series, as I've never seen the dyno runs comparing them.
'97 T-100 SR5
Re: spacer under the carb [Re: xrtim] #809838 05/06/07 02:59 AM
1
1986xtracab Offline
I have used a five gas analyzer at and as sson as you put a tornado in it does reduce hydrocarbons (unburnt fuel) in the exhaust
1986 xtra-cab 22re
stock everything
1991 bed
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6036 MB (Peak: 0.6680 MB) Data Comp: Off Server Time: 2026-10-24 07:30:37 UTC
