Gearing #809850 05/05/07 06:33 AM
rustylux Offline OP
Howdi all. I've got a 1982 diesel dual cab yota and I would like to fit larger rims/tyres.
I looked up the axle code (G142) which equates to a 8" 2 pinion diff with 4.875 gear ratio. My question is do you guys think I could run anything bigger than 31 x 10.5 R15's without having an undrivable slug. Keep in mind that it is a 2L diesel with about 3/4 the HP of your 22R/RE's.
At the moment I have little 215 R16 cheese cutter tyres on (my 31x10.5's in my sig were slick and I got these for free) and I get stuck in anything deeper than 2".
Thanks in advance
Re: Gearing [Re: rustylux] #809851 05/06/07 05:16 AM
cktoy Offline
I think you would be a slug with much bigger than 31s
oh what a feeling:
#1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered
#2 86 sr5 4x4 efi parts truck
#3 87 2wd parts truck
84 supra yard art
Re: Gearing [Re: rustylux] #809852 05/06/07 07:38 AM
Snowtoy Offline
What is the stock tire size for a diesel? The 4.87 gear ration here in the state's was for auto's with 31's. If teh stock tires size for deisel and 4.87's was 28's, it is unlikely you would want to run anything bigger than the 31's you have been running. If diesel isn't cheaper than gasoline, you might consider swapping in a 22r, you could then run 33's(w/o a susp. lift), and have 28's and 4.10's performace and mileage, though w/o the torque ft's you now have with the deisel.
Are there HP mods you can do for the Toy diesel, i.e., turbo's, propane injection etc. If you can bump the performance to better match the tires, you could probably run bigger tires. You could also regear to 5.29's.
Re: Gearing [Re: Snowtoy] #809853 05/06/07 11:33 AM
rustylux Offline OP
Thanks for the input guys. I might just stick with the 31x10.5r15's and just air down to 15psi or so on sand.
Or I might combine my love of Fords and Yotas and shove a 351ci Cleveland in her <img src="/forums/images/graemlins/nana.gif" alt="" />
Re: Gearing [Re: rustylux] #809854 05/07/07 07:50 PM
SALMONHEAD Offline
The way sand sucks power, I would stick with the 31x10.5 for sure. You need to air down no matter what tire size you have anyway. I run my 33x9.50 BFG AT's in the sand at 10-12psi and they do a nice job.
84 4RUNNER,22R,HEDMAN,WEBER 32/36,Davis Unified Ignition,33" BFG
Re: Gearing [Re: rustylux] #809855 05/07/07 09:10 PM
Snowtoy Offline
Sand is a lot like snow, you should air down to below 10psi, probably closer to 5 psi. You want as alarge of a contact patch you can get, so the lower the psi you can go, the better traction you can achieve.
Even if you do shoe-horn in a 351, you would still need to lower the tire pressure.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6101 MB (Peak: 0.6801 MB) Data Comp: Off Server Time: 2026-06-07 04:24:14 UTC
