1985 Toyota 4WD w/ Tacoma engine (2RZ-FE) #810114 05/07/07 01:14 AM
A
alfio Offline OP
it's an 1985 toyota 4WD that has been completely restored. i took the truck off the rails and prepped and resprayed the frame with fresh coats of primer and finished in black. the underside of the cab has also been totally refinished, getting the same treatment as the frame but adding a good layer of undercoating to sensitive areas. on the top side the truck was completely stripped, sanded and prepped for fresh paint (charcoal gray). this was not an earl scheib paint job, it was professionally done and it was pricey. because everything was removed it (windshield, rubber, wiring, etc) basically looks like factory paint, even the engine bay was sanded and sprayed.
the interior was sanded and prepped for the application of a rubberized/epoxy finish. i wanted something that would let me skip interior carpeting while providing a fair amount of sound deadening. i found a rustoleum product (at $140 a gallon) that works and looks great. it's a gray color that matches the exterior.
the bed was also stripped and resprayed with fresh primer. it's set up for spray-on bedlining or a traditional liner. i also had a camper shell painted to match (it looks like a 4runner shell).
basically it's a brand new truck, the bodywork is super straight and the paint is quality stuff (base coat/clear coat). the mechanical stuff is easier to list than explain so here it goes:
*2RZ motor (one with about 50K miles). engine mounts were relocated.
*2RZ stainless steel header
*W56 transmission, fresh rebuild by cal mini trucks, still under warranty.
*brand new clutch
*brand new V6 radiator
*fresh rebuilds on front and rear axles
*brand new seats off a 2004 honda civic
the truck is now on ebay -- PM me if you are interested
alfio
Re: 1985 Toyota 4WD w/ Tacoma engine (2RZ-FE) [Re: alfio] #810115 05/07/07 01:49 AM
kewlynx Offline
Location per guidelines please.
BTW, congrats on the conversion. <img src="/forums/images/graemlins/notooth.gif" alt="" />
**ubi apis- ibi salus**
Re: 1985 Toyota 4WD w/ Tacoma engine (2RZ-FE) [Re: kewlynx] #810116 05/07/07 05:21 AM
A
alfio Offline OP
sorry about that
the truck is in bloomington, indiana
Re: 1985 Toyota 4WD w/ Tacoma engine (2RZ-FE) [Re: alfio] #810117 05/07/07 05:26 AM
Peli Offline
I think he is in INDIANA if not his truck has a twin in bloomington
and bump nice looking truck
1989 toyota 4runner 5speed 4" lift
Re: 1985 Toyota 4WD w/ Tacoma engine (2RZ-FE) [Re: Peli] #810118 05/08/07 02:55 AM
A
alfio Offline OP
yup, that's exactly where i am -- what do you drive? i must have seen yours as well.
alfio
Re: 1985 Toyota 4WD w/ Tacoma engine (2RZ-FE) [Re: alfio] #810119 05/09/07 06:18 AM
A
alfio Offline OP
bump
Re: 1985 Toyota 4WD w/ Tacoma engine (2RZ-FE) [Re: alfio] #810120 05/09/07 10:50 PM
A
alfio Offline OP
the truck was just listed on ebay, starts at $3000.00 (see first post for the link to the auction)
alfio
Re: 1985 Toyota 4WD w/ Tacoma engine (2RZ-FE) [Re: alfio] #810121 05/11/07 01:54 PM
A
alfio Offline OP
bump
u
m
p
Re: 1985 Toyota 4WD w/ Tacoma engine (2RZ-FE) [Re: alfio] #810122 05/16/07 03:01 PM
A
alfio Offline OP
last few hours.... this will sell today!
alfio
Moderated by  4x4Wire, Mudraider
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6218 MB (Peak: 0.7087 MB) Data Comp: Off Server Time: 2026-06-24 13:16:56 UTC
