Tilting pinion up cv only??? #810127 05/07/07 02:28 AM
8
84YOTA Offline OP
So i am at a point in the build where i want to get my perches welded up. But i am not to sure about the pinion angle. Right now i have it tilted toward the t-case.
my ds angle reads:=21 degrees
My flange reads:20 degrees
t-case flange:3 degrees
Does this seem close the two are with in a degree to eachother what are some magic numbers here?
I am planing on buying a nice cv driveshaft later on when i get dual cases. but want to have the pinion somewhat set in its place.
For now i have a stock 92 4runner ds mounted up for mach up. and in the process of making a sqaure tube drive shaft for a temporary solution
Any input would be helpful. especially the bad <img src="/forums/images/graemlins/cheers.gif" alt="" />
84 toyota std cab with stuff on it
Re: Tilting pinion up cv only??? [Re: 84YOTA] #810128 05/07/07 02:33 AM
toyotaguy55 Offline
yes only tip with CV
you want this
toyotas look good with body damage
Re: Tilting pinion up cv only??? [Re: toyotaguy55] #810129 05/07/07 02:55 AM
4Crawler Offline
Re: Tilting pinion up cv only??? [Re: toyotaguy55] #810130 05/07/07 03:24 AM
8
84YOTA Offline OP
you want this
can you better elaborate on that sketch?
With a cv it has to be exactly at zero degrees?
Re: Tilting pinion up cv only??? [Re: 84YOTA] #810131 05/07/07 11:44 AM
toyotaguy55 Offline
Phasing:
Phasing is a term that describes the alignment of the single-cardan joints on opposite ends of the drive shaft. As discussed above, a single-cardan (or u-) joint does not rotate at a constant velocity if the operating angle is non-zero. The drive shaft speeds up and slows down slightly as it rotates due to the nature of the joint. One way to reduce this is to make sure the joints at each end of the drive shaft are aligned properly. If the yokes on each end of the shaft line up with each other, as seen in the figure below:
Then the affect will be that the two joints will tend to cancel out the speed variations from each other. In most 4x4 applications, the drive shaft will have a slip yoke in the middle to allow for changes in length. If the shaft is ever taken apart, it is important to get it re-aligned properly when it is re-assembled. One way to do this is to mark both sides of the slip yoke. However, you should check that the joints really do align properly, don't assume they are. The reason for the phasing is that the speed variation of the joint is related to its operating angle and its angle of rotation. In order to get the most effective cancellation, the joint yokes *must* be aligned exactly with each other and the operating angles must be identical. Any variation in either angle will show up as uncancelled vibration. While unequal operating angles result in a vibration that increases with shaft RPM, phasing problems may be felt at lower RPMs and higher loads, like when accelerating from a stop.
Most driveshafts will have some sort of alignment mark stamped or painted on to indicate the proper orentation of the slip yoke. If there is none, they try lining up the u-joint end caps as close as possible. One trick that can sometimes help with phasing is to spin half of the driveshaft 180 degrees before re-installing it to see if this makes any difference. Often one orientation may balance out better than the other. Once you find the proper alignment, paint a mark on both sides of the slip yoke so that you can get it back together correctly next time.
For a double cardan driveshaft, phasing is not an issue, although you may want to try and line up the bearing caps anyway.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6100 MB (Peak: 0.6917 MB) Data Comp: Off Server Time: 2026-06-10 06:24:48 UTC
