steering
#810146
05/07/07 03:28 AM
85 ext. cab 3" lift springs 31" tires drove fine.put 3" longer shackles front+rear,35" used tires and now steering wheel moves back and forth at about 35-40mph(not a vibration).I screwed up and didn't drive it after shackles,before tires. just looking for some input before i change all four tires back.also does anyone know any driveshaft close to length needed to get rid of carrier bearing.thanks
Re: steering
[Re: kc85]
#810147
05/07/07 03:51 AM
Likely tire, used tires can be worn unevenly. Check them for balance and roundness and try swapping front<->back and see if anything changes. Also could be excessive caster angle, you typically add 1 degree per inch of added shackle length: - http://www.4crawler.com/4x4/ForSale/Shackles.shtml#FAQ12
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.5884 MB (Peak: 0.6364 MB) Data Comp: Off Server Time: 2026-11-02 14:12:07 UTCValid HTML 5 and Valid CSS
