Page 3 of 10 1 2 3 4 5 … 9 10
Re: My "Budget" Build Thread [Re: 4xToy] #810168 05/29/07 03:25 AM
9
94redrodeo Offline
lookin sweet
94 Rodeo 3+3 lift Red)
95.5 Rodeo 1" Body lift Dana 44' front & rear 4.88 gears 35"s 176,000 miles Optima Yellow top InexAir Co2
front winch bumper custom rear bumper, Hella 500's
2004 Silverado duramax
Re: My "Budget" Build Thread [Re: 94redrodeo] #810169 06/07/07 03:27 AM
4xToy Offline OP
I did some test fitting today after work. It looks like a real nice fit. I think I can utilize the factory motor mount pads on the frame. I can probably adapt a set of stock 4.3 motor mounts to work but I question the reliability of them. Every set I've ever pulled off have been broken.
A few issuses I will have to deal with are the fuel and brake lines running down the frame rail. I will probably move them to the outside of the frame for safe clearance of the exhuast. It looks like I can use the stock manifolds for now. I will eventually upgrade to headers when money permits. The only other challenge I see right now with fitment is my power steering lines will have to make a loop straight up and back down to the box because the pump sits directly over the box. I may still install a scout box If I can figure out which one I need. I've got about 1 1/2" of clearance above the tranny and about 2" at the distributor. I will have to cut the core support some to clear the radiator and Taurus fan I will be running. I'm thinking about runnig a corvette radiator and a s10 shroud. It should keep things nice and cool even on really hot days. I've got a Taurus fan on my '90 s10 DD behind the stock shroud and it never gets above 195*
PICS>
-Chad
Re: My "Budget" Build Thread [Re: 4xToy] #810170 06/10/07 02:03 AM
4xToy Offline OP
Got a lot done today. I worked on my harness and got everything figured out (I think) and fitted some motor mounts I got from a 85 bb Chevy. They are going to work real nice. I welded on new mounting plates to the frame and before I pulled the motor back out and change all the gaskets and painted it. I still don't know what I'm doing for a t-case but I'm really leaning toward the np208. I just wish there were some good mods I could do to it to make it a little better like gears and SYE.
I hope to have the engine back in this week. I still need to finish grinding the rest of the IFS junk before I drop the motor back in.
-Chad
Re: My "Budget" Build Thread [Re: 4xToy] #810171 06/10/07 05:49 PM
4xToy Offline OP
-Chad
Re: My "Budget" Build Thread [Re: 4xToy] #810172 06/11/07 02:43 PM
W
warpig Offline
Looks great, you've really made some progress since I last checked. Thanks for all the (good quality) pictures, It really helps me visualize everthing for my swap. <img src="/forums/images/graemlins/kewl.gif" alt="" /> Keep 'em coming, and good luck.
BTW, I'm now going with a Dana 300/T700r4 setup. Tim.
Re: My "Budget" Build Thread [Re: 4xToy] #810173 06/11/07 03:42 PM
BigSwede Offline
Lookin' good; I always liked the 4.3L...
Serenity now!
Re: My "Budget" Build Thread [Re: BigSwede] #810174 06/12/07 03:14 AM
4xToy Offline OP
does anyone know if the np208 adapter is the same 6bolt pattern as the dana300? They sure look an awful lot alike. It seems like I heard that you can use a 208 adapter to mate a d300 with a little modification. I just can't justify spending $500 on a little adapter. That is more than I bought a whole running drive train for <img src="/forums/images/graemlins/scared.gif" alt="" />. I really don't want to run the np208, but unless I can find another cheaper alternative I'm gonna hae to go that way.
I know antoher expensive option is a toyota case which I would like that too but it's $600
-Chad
Re: My "Budget" Build Thread [Re: 4xToy] #810175 06/12/07 03:28 PM
Bigpoppax2 Offline
Andre, (starchild) did it.
I think one bolt wouldn't work, so it ended up being a 5 bolt adapter. Other than a o-ring seal I don't think he's had any issues with it. He tried to seal it with RTV and it wasn't working, once he put the o-ring seal in place he's not had any issues.
I'll ask him to pop in here and give you some direction.
Joe
Re: My "Budget" Build Thread [Re: Bigpoppax2] #810176 06/12/07 03:37 PM
Starchild Offline
Like Joe said, the 208 adapter works fine with the D300. You will need to replace the D300 input shaft with a 27 spline one to mate to the 700R4. I got mine from JB Conversions. They have a couple different lengths for different adapters, but they were familiar with this setup and got me the right one.
Yeah, don't forget that one <img src="/forums/images/graemlins/scared.gif" alt="" />
<img src="/forums/images/graemlins/cheers.gif" alt="" />Andre
"SERENITY NOW!"
Re: My "Budget" Build Thread [Re: Starchild] #810177 06/12/07 10:48 PM
4xToy Offline OP
Ok, is the dana300 shaft a female shaft that slides on to the 700r4 shaft? I've never seen a dana300 out of a vehicle. The adapter that came off of the original np233 (Push Button 4wd) is only a 5 bolt pattern <img src="/forums/images/graemlins/confused.gif" alt="" /> I've never seen one of those either, until now. Is there not enough material on the 208 adapter to re-drill the 6th hole?
I'll check out jb conversions I can pick up a 208 adapter for like $25
Thanks guys for the help.
Chad
-Chad
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.006s) Memory: 0.6488 MB (Peak: 0.7773 MB) Data Comp: Off Server Time: 2026-10-24 07:18:34 UTC
