power steering ? #810267 05/07/07 07:04 AM
rollin Offline OP
Hello my 1989 (first gen) 4runners power steering is using fluid, but I can find no leaks. I can't figure out where its going ,but I have to add fluid about every other day.Its only a few oz but what the heck . Is the power steering fluid going into one of the vac lines that come into a valve at the bottom rear of the pump? <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: power steering ? [Re: rollin] #810268 05/08/07 08:25 AM
Kutter Offline
Have you tried steam cleaning the engine bay then monitor to see if you can see any leakage. You have no puddles on the ground?
If somehow it managed to get into the engine through an intake line, a few ounces every other day should be evident by smoke from the tailpipe I would think.
1995 4Runner Limited V6 3.4 Liter 5 Speed 4x4
1995 4Runner V6 Auto 2WD
Re: power steering ? [Re: Kutter] #810269 05/08/07 01:23 PM
rollin Offline OP
Yes, I have cleaned the engine and can find no leaks ! This is one fo the stangest things I have seen.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5934 MB (Peak: 0.6463 MB) Data Comp: Off Server Time: 2026-06-07 10:15:16 UTC
