94 Cherokee - Testing Fuel System #810370 05/08/07 01:20 AM
A
antheil Offline OP
I am still struggling with my 94 Cherokee. I am beginning to think it may not be getting enough fuel. It is intermittent, sometimes it barely idles and the sometimes idles ok but still seems to lack enough fuel at higher RPM. I have changed the filter and it was BAD (very dirty). How many fuel systems components are there? Pump, Filter, Relay, and Injectors û anything else? How can I test the system? Any ideas and help would be greatly appreciated
Re: 94 Cherokee - Testing Fuel System [Re: antheil] #810371 05/08/07 08:31 PM
MrCrowley Offline
my dad had the same problen with his jeep and he sold it so the guy that boutht it got to looking at it and th fuel filter was really dirty as yours was and after he changed it it kept up the rought running and hegot to looking ant the air filter was matted pretty bad with all kinds of road grit. he changed it and cleaned the filter tube and it quit doing it. so i dont know if it will work for you but its worth a try
Re: 94 Cherokee - Testing Fuel System [Re: antheil] #810372 05/11/07 06:05 AM
jtkasprick Offline
You should start by checking fuel pressure, Your system should have a spec( Iam not at work and do not have a manual at home so i am not sure the spec)for how mush Psi the systwm should supply. Also you can check how much current draw the fuel pump is drawing. If it is out of spec it could be a wiring problem or a bad pump. There is also volume testing. This test will tell how much fuel is being pumped to the fuel rail. If you are not sure how do do these tests it is best to leave it up to a certifed Technician.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5913 MB (Peak: 0.6443 MB) Data Comp: Off Server Time: 2026-06-17 13:16:48 UTC
