Rear axle seals #810461 05/08/07 10:16 PM
The_Rusty_Gear Offline OP
I seem to be doing these every year. Maybe IÆm damaging them or not installing them correctly (crooked, not properly seated etc)
How can I make sure to do the job RIGHT?
Use a seal driver? How far do I drive the seal in? Extra careful when re-installing the axle?
Any hints and tips are extremely appreciated. IÆm going to be replacing the rear wheel bearings as they are growling at me (can a bad bearing be causing the latest leak, or is it likely the leak washed out the bearing causing it to go bad? Chicken or the egg?)
The only thing I'm pretty sure I'm doing correctly is greasing the rubber part of the seal before installation.
Thanks!
1988 4Runner, V6 Auto, Mostly Stock
32 x 9.5 Swampers
Re: Rear axle seals [Re: The_Rusty_Gear] #810462 05/08/07 10:23 PM
ErikB Offline
Toyota Moderator
Yes, a bad bearing can cause a leak and yes a leaky seal can also wash out the grease in the bearing since the oil has to leak through the bearing to get to and past the outer seal.
If/when you get an oil leak, I'd recommend using a needle attachement on your grease gun, sliding it under the bearing seal lip and filling the bearing back up with grease when you replace the seal. Might be a good idea any time you have your shafts out for that matter (while swapping a 3rd, etc.).
http://home.4x4wire.com/erik
Re: Rear axle seals [Re: ErikB] #810463 05/08/07 10:26 PM
coryc85 Offline
That's a great idea with the needle attachment.
Marlin has some new axle seals with a lip that supposedly helps get them in there straight.
83 4x4, 3" Lift, 33" Buckshot Mudders
Re: Rear axle seals [Re: coryc85] #810464 05/09/07 02:10 AM
1
1986xtracab Offline
is the breather on your axel working properly? or is it clogged. If it is clogged it could be building up to much pressure and blowing out thre seals.
1986 xtra-cab 22re
stock everything
1991 bed
Re: Rear axle seals [Re: 1986xtracab] #810465 05/09/07 04:06 AM
cktoy Offline
x 2 on check the braether.mine was stopped up causing pres to build up when it got hot and push oil out the seal.I replaced the stock breather with one off an old pathfinder and added enough hose to get the outlet out of harms way.make sure there are no low spots in the hose to trap moisture
oh what a feeling:
#1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered
#2 86 sr5 4x4 efi parts truck
#3 87 2wd parts truck
84 supra yard art
Re: Rear axle seals [Re: The_Rusty_Gear] #810466 05/09/07 04:40 AM
jasonmt Offline
I now have to think that your truck is cursed Mike and suggest an exorcism or replacement with a JDM 80 series...
Re: Rear axle seals [Re: cktoy] #810467 05/09/07 03:00 PM
Extended breathers working fine with no low spots. Thanks for the input!
32 x 9.5 Swampers
Re: Rear axle seals [Re: jasonmt] #810468 05/09/07 03:06 PM
I think it's been cursed for awhile. I blame all of the previous four owners of the truck smile
And don't you be tempting me with a sweet sweet JDM 80! I couldn't handle the happiness!
32 x 9.5 Swampers
Re: Rear axle seals [Re: The_Rusty_Gear] #810469 05/09/07 09:03 PM
OOP'S Offline
Besides all the other suggestions,a bent housing can cause a leak, a bent axle shaft can cause a leak.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.011s) Memory: 0.6293 MB (Peak: 0.7329 MB) Data Comp: Off Server Time: 2026-11-19 05:32:47 UTC
