Page 1 of 3 1 2 3
When I remove my doors, how do I get the dome lights to stay off? #810798 05/09/07 09:05 PM
L
linworthas Offline OP
Thanks.
Re: When I remove my doors, how do I get the dome lights to stay off? [Re: linworthas] #810799 05/09/07 09:29 PM
BobRowe Offline
What kind of vehicle are you talking about?
Re: When I remove my doors, how do I get the dome lights to stay off? [Re: BobRowe] #810800 05/10/07 01:54 PM
CoronaJeeper Offline
On my TJ, I got behind the switches on each door jamb and unplugged them. Or you could buy these little clips that go over the switch to hold it in. I think most Jeep parts places sell them. I'd check with Quadratech.
Corona <img src="/forums/images/graemlins/cheers.gif" alt="" />
'98 TJ, 4 cyl., auto
31" AT KO's on rockcrawlers,
custom bumpers, Hellas
2" Teraflex lift, no top,
no doors, no problem.
Re: When I remove my doors, how do I get the dome lights to stay off? [Re: BobRowe] #810801 05/10/07 03:00 PM
L
'04 Wrangler
I've looked at the fuses under the hood and behind the glove box, but nothing seems right.
had: '74 CJ5, '81 CJ7; have: '04 Wrangler, '90 Wrangler (my son's; yes, I'm proud)
Re: When I remove my doors, how do I get the dome lights to stay off? [Re: linworthas] #810802 05/10/07 03:21 PM
Macdaddy4738 Offline
theres a fuse (at least on my 98) called the DOOR INTERRUPT SWITCH.
Pull it and it works as though your doors are closed all the time.
Re: When I remove my doors, how do I get the dome lights to stay off? [Re: Macdaddy4738] #810803 05/10/07 04:45 PM
DBL_DTY97TJ Offline
If you pull the fuse the dome light cannot be turned on when needed. Pull the wires from behind the switch on the door. You can put them back on later if you want to....I never have.
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: When I remove my doors, how do I get the dome lights to stay off? [Re: CoronaJeeper] #810804 05/10/07 06:22 PM
L
To remove the wires behind the switch on the door, do I need to dismantle the edge of the dash?
I went to the Quadretech website and saw a "TJ Dome Light Switch." It looks like a great solution; does anyone know how big of a hassle it is to install?
Re: When I remove my doors, how do I get the dome lights to stay off? [Re: linworthas] #810805 05/10/07 06:44 PM
DBL_DTY97TJ Offline
Don't need to dismantle anything. Just reach up behind the inside edge of the door frame behind the switch and you will feel the wire. Follow it to the switch and pull off while holding onto the piece that fits to the back of the switch. It may take a little wiggle - can't quite remember, but it is very easy and can be put back on. Not that I think you'll ever bother if you like having the doors off. I never put the nuts back on the door hinges either (BTW that's a 13mm and you need an angle dohickey for the ratchet or a wobble head - angle thing usually comes with standard ratchet set). Then all you'll need is a foot peg for the lower hinge hole so you can hang your leg out and really look cool! <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: When I remove my doors, how do I get the dome lights to stay off? [Re: DBL_DTY97TJ] #810806 05/13/07 12:23 AM
fishtaker Offline
On my 03 TJ when I pull fuse #4 behind the glove box, the lights go out. They will come on when the vehicle is shut off and I can rotate the interior light dimmer switch and turn them on.
03 TJ 5 Speed I-6 30X9.50 BFG KO's
Re: When I remove my doors, how do I get the dome lights to stay off? [Re: fishtaker] #810807 05/14/07 01:46 PM
DBL_DTY97TJ Offline
?????With the fuse pulled?
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6350 MB (Peak: 0.7576 MB) Data Comp: Off Server Time: 2026-07-14 10:41:57 UTC
