'89 LWB Monty high idle...
#811096
05/10/07 09:08 PM
Is there a way to lower my idle RPM from 1200 to factory spec 800 without retarding the timing? I've cleaned the injectors, smog report says O2 sensor is fine..air screw turned all the way in...what now? Sorry if this is a repeat but didn't see anything in the archives.. <img src="/forums/images/graemlins/confused.gif" alt="" />
'89 LWB 3.0 5spd bouncy seat 31" no lift yet....
Re: '89 LWB Monty high idle...
[Re: xcanuck]
#811097
05/10/07 09:27 PM
check IAC (Idle Air Control) or TPS (Throttle Position Sensor) That was the culprit in my high idle. Good Luck! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Richard E 1989 Montero - Stock-ish 1989 V6 Auto Raider - 5.3 Vortech Swap. 1987 Mitsubishi Starion 2.6t, soon to be 3.5 1983 Honda XL600R
[Re: StockRaider]
#811098
05/10/07 10:02 PM
[Re: xcanuck]
#811099
05/10/07 10:20 PM
I replaced the IAC and all was well after that. I hear you can clean it using brake cleaner, but never tried it. I bought my replacement from Dough's old truck. Using an old one is really hit or miss.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6027 MB (Peak: 0.6580 MB) Data Comp: Off Server Time: 2026-11-02 12:29:04 UTCValid HTML 5 and Valid CSS
