'89 LWB Monty high idle... #811096 05/10/07 09:08 PM
X
xcanuck Offline OP
Is there a way to lower my idle RPM from 1200 to factory spec 800 without retarding the timing? I've cleaned the injectors, smog report says O2 sensor is fine..air screw turned all the way in...what now? Sorry if this is a repeat but didn't see anything in the archives.. <img src="/forums/images/graemlins/confused.gif" alt="" />
'89 LWB 3.0 5spd bouncy seat 31" no lift yet....
Re: '89 LWB Monty high idle... [Re: xcanuck] #811097 05/10/07 09:27 PM
StockRaider Offline
check IAC (Idle Air Control) or TPS (Throttle Position Sensor) That was the culprit in my high idle.
Good Luck! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: '89 LWB Monty high idle... [Re: StockRaider] #811098 05/10/07 10:02 PM
X
xcanuck Offline OP
Did you replace it?
Re: '89 LWB Monty high idle... [Re: xcanuck] #811099 05/10/07 10:20 PM
StockRaider Offline
I replaced the IAC and all was well after that. I hear you can clean it using brake cleaner, but never tried it. I bought my replacement from Dough's old truck. Using an old one is really hit or miss.
Richard E
1983 Honda XL600R
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6020 MB (Peak: 0.6572 MB) Data Comp: Off Server Time: 2026-11-03 13:35:11 UTC
