Page 3 of 3 1 2 3
Re: Sounds like there's a gnome with a hammer under my Gen2 [Re: Oyaji_Jon] #811177 05/12/07 09:41 PM
justice Offline
That's what I wanted to know. The system is similar to my wife's Rodeo, then. Our Rodeo doesn't have the diff lock, though. Anyway, I understand the desire for 4 hi in slick conditions, but can't driving in 4wd at high rates of speed/all times damage the system? At the least it HAS to be rough on the tires, right? I wouldn't run my trucks that way.
Back on topic, with the system working the way it does, I do agree that your CVs COULD be suspect. Gotta check it out, man...
No the Gen II T-case was kind of an innovation at the time it was introduced as it was one of the first cases to give you four choices. 2wd, 4 hi, which is basicly like a subaru AWD, 4hiLC which is like a standard 4 hi with case diff locked and of course 4lo. with the gen 2 you can shift into 4hi at up to 60mph according to the owners manual.
Re: Sounds like there's a gnome with a hammer under my Gen2 [Re: justice] #811178 05/13/07 01:10 AM
Oyaji_Jon Offline
Ha, that sounds really cool! I didn't know about all of that stuff. Thanks for the explanation.
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: Sounds like there's a gnome with a hammer under my Gen2 [Re: justice] #811179 05/13/07 01:49 AM
MonkeyProof Offline
it maybe the carrier(sp?) bearing gone bad. it's around your drive shaft and connected to a bracket. it sits more or less half way from the rear end and the trans. i had mine replaced once so far at my 110k mark.
if you need a pic of what it looks like let me know and i'll post one.
"STOP or I'LL RELEASE MY DOG!"
Re: Sounds like there's a gnome with a hammer under my Gen2 [Re: nedfunnell] #811180 05/15/07 05:39 AM
nedfunnell Offline OP
My parents took it to a shop today, and upon my suggestion, had the CV joints inspected as a potential cause of the noise. The shop said that it was, and that the half-shaft(s?) would need replacing. (Fuzzy on that detail- not sure if they recommended one or both)
Anyway, I ran across this thread tonight, and I think that could very well be my problem! The sound is from the passenger side only, and the fact that the shop said the axle needed replacing is a big indicator. Now that I've got this info(and pics from that thread), I want to go down to the mechanic that looked at it and see if that's what he saw inside.
Man, I wish I had a lift(or even some jackstands and a floor jack) so I could look at it myself.
Anyway, this is a cool new lead. If this is the problem, could making a spacer like Richard did in that thread fix my problem if the shaft isn't torn up too bad? That's what it looks like he did. I could fab that myself, too.
95 Montero SR - 207k miles, rebuilt @ 146k
Stock. Longview, Texas
Ithaca, NY for the summer of 08.
Re: Sounds like there's a gnome with a hammer under my Gen2 [Re: nedfunnell] #811181 05/15/07 06:04 AM
StockRaider Offline
It's not as fun as it seems Ned.
Why thars ur problem rite ther! <img src="/forums/images/graemlins/notooth.gif" alt="" />
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Sounds like there's a gnome with a hammer under my Gen2 [Re: StockRaider] #811182 05/15/07 06:07 AM
You mean I have to take the whole front diff off just to get to the halfshafts and CV joints?! No way! <img src="/forums/images/graemlins/zombie.gif" alt="" />
(I apologize for sounding like a newbie, but, well okay I'm a newbie <img src="/forums/images/graemlins/baby.gif" alt="" />)
Re: Sounds like there's a gnome with a hammer under my Gen2 [Re: nedfunnell] #811183 05/15/07 06:17 AM
StockRaider Offline
Im not sure if you have to completely remove the axle carrier, but it makes it easier to replace the clip and the possibly ruined outer seal.
Richard E
1983 Honda XL600R
Re: Sounds like there's a gnome with a hammer under my Gen2 [Re: nedfunnell] #811184 05/15/07 06:21 AM
StockRaider Offline
Don't you get frightened by the look of my Montero's underbelly. I am just very messy when I work <img src="/forums/images/graemlins/notooth.gif" alt="" />.
Richard E
1983 Honda XL600R
Re: Sounds like there's a gnome with a hammer under my Gen2 [Re: StockRaider] #811185 05/15/07 02:25 PM
madmitch Offline
I haven't read this whole thread, but if it sounds like there's a gnome with a hammer, I'd check to see if it is making regular beats, regardless of speed.
...Because that would be a metrognome
[color:"red"]1992 Monty SR, bouncy seat, custom steering wheel, torsion lift, BFG 31" AT, luxurious wood interior. 230k. [/color]
"Give the bully another point."
Re: Sounds like there's a gnome with a hammer under my Gen2 [Re: madmitch] #811186 05/15/07 07:59 PM
stony-man Offline
Well, you can also tell if his eyebrows have been waxed, right? <img src="/forums/images/graemlins/smile.gif" alt="" />
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6433 MB (Peak: 0.7698 MB) Data Comp: Off Server Time: 2026-06-07 04:51:38 UTC
