Ball Joint Spacers #811364 05/11/07 06:50 PM
IceBlueT Offline OP
hey all.
ive been on here for a while, and i gotta ask, what are ball joint spacers? ive seen a few rigs that people say that it has 1.5 ball joint spacers, and im a little confused as to what they are, how they help, and how hard they are to install.
thanks! <img src="/forums/images/graemlins/kewl.gif" alt="" />
formerly 277000_yota
Old enough to know better, but still to damn arrogant to care...
]www.cardomain.com/ride/2614269
'90 'Yota 4X4 (10/31/05-09/10/08 R.I.P)
'98 'Yota t-100. 3.4, 5 sp. 4x4, 2 in. Toytec with BFG A/T 265/70R16s
Re: Ball Joint Spacers [Re: IceBlueT] #811365 05/11/07 07:00 PM
4Crawler Offline
Ball joint spacer information, including installation:
- http://www.4crawler.com/4x4/ForSale/BallJointSpacer.shtml
Basically they space down the spindle/steering knuckle from the upper control arm for added lift and suspension travel:
Re: Ball Joint Spacers [Re: 4Crawler] #811366 05/11/07 07:05 PM
IceBlueT Offline OP
ok. so a few more questions. are they a cost effective way to get a little more lift? and do they cause damage to existing parts or cause premature ware? and where can i get them and for about how much?
P.S.-btw, im at school, and our schools server blocks your website 4crawler. sorry, ill look at it as soon as i can.
Re: Ball Joint Spacers [Re: IceBlueT] #811367 05/11/07 08:27 PM
ldivinag Offline
another advantage is that if you precranked your t-bars already, if you install these things, you will have less harseness in the ride since you are decranking the t-bars without loosing the lift...
leo d.
90 4runner, v6, auto, WCOR CitB kit,
marlin duals, arb rear, tt front
4.88, blah, blah, blah...
Pres. of TEAM IFS! and
GETTING OFF 4WD Club member
Re: Ball Joint Spacers [Re: IceBlueT] #811368 05/11/07 09:37 PM
G
GMJK86SR5 Offline
i have put them on two trucks and would do it again. BJ Spacers, with some trimming, maybe a 1 inch body lift, will be enough to run 33's. In my opinion, that is all you need to go offroad. I always take the easy routes. You will need to do a few more mods to go offroad effectively, but as far as tires go, 33's with BJ spacers are it. Best bang for your buck. I bought mine from 4crawler.
Mike
Re: Ball Joint Spacers [Re: GMJK86SR5] #811369 05/11/07 09:51 PM
N
norcalsvx Offline
i run the BJ spacers w/ OME torsion bars , i relaxed the t- bars for more flex, it fits my 33x10.50x15's with no rub
1994 toy 22re
Engbldr. street rv head 261c,LC header,Downey dualshocks, BJ spacers, OME torsions, 33x10.50 BFG muds budbuilt xmember/skid plate 4.88's locker custom exhaust
2006 Subaru Forester XT
1994 Subaru SVX
1979 Mazda rx7
Re: Ball Joint Spacers [Re: IceBlueT] #811370 05/12/07 02:44 AM
Vonka Offline
Heres mine I just about got mine aligned and with my new BFG At 33 x 12.5 tires on MT 10 wide rims.Just removed the valence.I have a 1" body lift,diff drop,1.5 BJ spacers,and 4:88 precision gears.
88 4x4 22re
86 2wd 1-ton 22re
91 2wd 22re
Re: Ball Joint Spacers [Re: Vonka] #811371 05/14/07 06:55 PM
IceBlueT Offline OP
i think thats the route im going to take. i found a set from San Diego Off Road Solutions for about $120, so now i just have to save the money to do it. did you guys have any problems putting them on? also, did you have to put new shocks on?
Re: Ball Joint Spacers [Re: IceBlueT] #811372 05/15/07 07:43 AM
Vonka Offline
I followed the installation instruction from 4Crawlers & San Diego Off Road Solutions.I had to buy a air tool hi speed cutter $30 to trim some of the metal to fit the
spacers.After that its pretty easy fit.
to be able to fit the 33's the Rancho shocks got stretched out so I found a pair of Pro-Comp shocks at the auto yard for $20.My ride is not too stiff but still comfortable.I still have to get longer shocks for the rear.Pro-Comp or Bilsteins is my choice.
88 4x4 22re
86 2wd 1-ton 22re
91 2wd 22re
Re: Ball Joint Spacers [Re: Vonka] #811373 05/15/07 07:06 PM
IceBlueT Offline OP
ya, i plan on only putting on 31's, since im going to be traveling to and from northern New Mexico for the next two years, so im not looking to go up higher than what my truck should have. do you think i will still need new shocks?
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6414 MB (Peak: 0.7622 MB) Data Comp: Off Server Time: 2026-10-26 01:11:17 UTC
