A 1991 LS next to me #811395 05/11/07 10:27 PM
G
guzzilapd Offline OP
found a 1991 LS next to me with the sunroof.
84k on the meter but the guy says cooling fluid is disappearing and its not leaking. Hes owned it for 2 months. Wants 2600.00 for it and I walked away.....
Another loser.
500.00 and I might take it. Hes buried in it.
Northern Va if any of u guys interested. It has a sunroof too..
s
Re: A 1991 LS next to me [Re: guzzilapd] #811396 05/11/07 11:13 PM
sparkem Offline
2600 is too much, wise choice.
Re: A 1991 LS next to me [Re: guzzilapd] #811397 05/11/07 11:15 PM
bathroomkiller Offline
Is the car only worth 500 because of the potential problem with the coolant? Or are you saying that the vehicle is only worth $500 because of the age and condition?
Sounds to me that if the car only has 84k, it's very low mileage (not withstanding the cosmetic condition of course).
Just curious. Thanks.
'91 Montero LS 3.0 V6 -currently bone stock-
Re: A 1991 LS next to me [Re: bathroomkiller] #811398 05/12/07 04:02 AM
Oyaji_Jon Offline
Yep, around here, it'd go for 2600 without the coolant leak. However, with leak, I'd pay under 1000 with the reasoning that I'm not sure how much it'll cost to fix it...
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: A 1991 LS next to me [Re: Oyaji_Jon] #811399 05/12/07 11:38 AM
G
Thats right. 500.00 Id buy it based on the fact Im gonna have to pull the heads to fix the leak. AND then while in there rebuild the heads, water pump, timing belt, front seat...etc etc. the list goes on and on.
We wont mention who knows if it needs brakes all around.
Other than that the vehicle is or looks in above average conditon.
Id send a pix alo with this if someone will explain how I attach one. Ive got a couple stored on my computer.
s
Re: A 1991 LS next to me [Re: guzzilapd] #811400 05/13/07 01:11 AM
dwehbie Offline
Are you sure it is the heads / gaskets?
Did you check the oil for coolant contamination?
Did you check the coolant for oil?
Might be the water pipe oring.
1996 Toyota T100
Re: A 1991 LS next to me [Re: dwehbie] #811401 05/20/07 09:20 PM
G
Owner said NO leaks. No water in OIL either. Must be burning it up little by little. Said it did get HOT but not up in the red....Might as well have been up in the red as far as Im concerned.
s
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6133 MB (Peak: 0.6912 MB) Data Comp: Off Server Time: 2026-06-17 10:36:55 UTC
