Timing Chain guides, dual chain conversion #811419 05/12/07 12:53 AM
Martini Offline OP
I've been fighting these things for years. I can't get the chattering to go away. The truck has been sitting for over year now, and I'm finally getting around to fix her. The chain is running heavily on the guides and is making a horrible sound. Has anyone had this problem? I did find the distributor gear making contact with the timing chain cover top bolt, but that can't be it. Notice the slots in guides? The one on the right is pointless because the lower hole isn't slotted. It looks like the things were miss drilled. Any input would help.
86' 4Runner, Manual 22RE, Grey SR5
05' 4Runner 4WD Sport, Silver
Re: Timing Chain guides, dual chain conversion [Re: Martini] #811420 05/12/07 01:23 AM
MAC Offline
could you have over-torqued your tensioner? only takes 9 ft-lbs (as per eb) and does not take much over that to ruin it sometimes. it can bind and leave the chain slack. been there...
Re: Timing Chain guides, dual chain conversion [Re: MAC] #811421 05/12/07 01:26 AM
CJM Offline
86 has a single chain ?
unless you have LC's conversion kit ?????
83 Trekker SR5
NEW Trekker forum
Re: Timing Chain guides, dual chain conversion [Re: MAC] #811422 05/12/07 01:32 AM
Martini Offline OP
Don't think so. I torqued everything per Haynes. This tensioner seems to be working properly, I put a new one in last go around. Same problem. This is the 4th time taking the timing cover off. I keep trying different guide positions. She runs great, except for the sound. This thing is wooping my ***. I'll triple check the torque on the tensioner.
Re: Timing Chain guides, dual chain conversion [Re: Martini] #811423 05/12/07 01:33 AM
Martini Offline OP
Yeah, it's a LC Engineering conversion kit.
Re: Timing Chain guides, dual chain conversion [Re: Martini] #811424 05/12/07 01:39 AM
CJM Offline
so probably the most important bolt it the top oil pump bolt ..
If it is the wrong one .. to long .. it will actually contact the tensioner , and interfer .
(as seen in the pic)
the correct bolt is very important in this case .
83 Trekker SR5
NEW Trekker forum
Re: Timing Chain guides, dual chain conversion [Re: CJM] #811425 05/12/07 01:45 AM
Martini Offline OP
She's flush.
Re: Timing Chain guides, dual chain conversion [Re: CJM] #811426 05/12/07 01:46 AM
mqm Offline
Did you drill out the oil splash guard directly underneath the oil cap? If the not the dual row timing chain WILL rub the splash guard.
Re: Timing Chain guides, dual chain conversion [Re: mqm] #811427 05/12/07 01:50 AM
Martini Offline OP
yup
Re: Timing Chain guides, dual chain conversion [Re: mqm] #811428 05/12/07 01:51 AM
CJM Offline
have you cantacted LC and asked them ?
83 Trekker SR5
NEW Trekker forum
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.006s) Memory: 0.6387 MB (Peak: 0.7619 MB) Data Comp: Off Server Time: 2026-06-07 04:36:52 UTC
