Sky Crossmember install - Help #811437 05/12/07 01:09 AM
Dingman Offline OP
I'm not getting my Sky Crossmember
Pirate install pics
to install, I can't get the hoop over the front TC flange, I asked Marlin twice if this was the right plate and they said it is. But I can't get it on. Can anyone look at the pic, or maybe someone has installed one and knows what my problem is (besides the damn thing weighing 5000 lbs).
My transfer case sure looks diff than the one in the Pirate pic. (I know it's not much to go on, but It's the only pic I have right now)
Re: Sky Crossmember install - Help [Re: Dingman] #811438 05/12/07 01:22 AM
Dingman Offline OP
Well, Doh. Searched some more, got to Sky's site and found this~
Fits 84-95 4 cyl trucks with manual trans and either daul t case's or single if you don't mind a little extra overhang. Please specify you will be using a single
Well, I guess it's my fault for trusting counter help to give me the right info\part. I should have done my own research and decided exactly what I wanted instead of succumbing to an inpulse purchase while I was on the phone ordering other parts.
I guess I get to go put my crossmember back on now.
Paved Roads ~ Another example of wasteful government spending.
'85 $runner, lifted and locked.
See the Ding_yota here
Re: Sky Crossmember install - Help [Re: Dingman] #811439 05/12/07 02:11 AM
OOP'S Offline
I think but I may be wrong, the reason you are having a problem is your rig is an auto tranny and the t-case is different then the gear drive t-case. Those x-members are built for manual trannys with gear drive t-cases only I think.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Sky Crossmember install - Help [Re: OOP'S] #811440 05/12/07 02:23 AM
Dingman Offline OP
Yes, that's it. I've just never done any of this before and so I'm easily cornfused when I get a wrong part. smile
Thanks for your help.
Re: Sky Crossmember install - Help [Re: Dingman] #811441 05/12/07 02:27 AM
OOP'S Offline
Again I may be wrong but I think that BudBuilt can set his up for the auto tranny. Give Bud a call.
http://www.budbuilt.com/new/
David Fritzsche
Roseville, CA
Re: Sky Crossmember install - Help [Re: OOP'S] #811442 05/12/07 02:45 AM
Dingman Offline OP
Thanks, I'll do that. That was actually the one I asked for while on the phone with Marlin but either they didn't have one or something - can't remember now why I changed my mind. Bad move on my part.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6093 MB (Peak: 0.6803 MB) Data Comp: Off Server Time: 2026-07-13 10:57:25 UTC
